Narrowing rear C5Z wheels?
Old Sep 4, 2018 | 11:41 PM
C5ZOwnersAssociation's Avatar
Cruising
Default Narrowing rear C5Z wheels?
Has anyone ever had a pair of 10.5" rear OEM wheels from a C5Z cut in half and narrowed by 1" to fit flush with the fenders up front? I have bought a pair and it will cost $350 to have them cut in half, remove 1" width, and welded back together. This would allow me to keep the OEM wheels and put C6 front brake calipers from a Z06 or Grand Sport up front.
Old Sep 4, 2018 | 11:50 PM
Never even thought about doing that, but good luck if you decide to get it done.
Old Sep 4, 2018 | 11:58 PM
z06801's Avatar
z06801
That will only change the backspace. The fit to the fender won't change.
Old Sep 4, 2018 | 11:59 PM
chevyave's Avatar
chevyave
I did to run six piston Wilwood brakes with C6 ZO6 rotors. The wheels cleared the brakes perfectly and also allowed smaller tires on the front to keep the factory stagger and not affect the stability control systems. Could not have been happier with the results and it cost me around $300 for the pair.
Old Sep 5, 2018 | 03:37 PM
chevyave's Avatar
chevyave
Agreed, narrowing the wheels does not affect the offset, but it eliminates the need to run 295 tires on the front and the possible rubbing of the tires on the inner fender wells. It also allows you to keep the factory stagger to eliminate any potential problems with the stability control systems. In my opinion running a "squared" tire setup with 295 rubber on all four corners is not ideal for a street car. It might be great for autocross or road racing, but having to turn into parking spaces where the tires might rub or the front end pulling in the direction of road ruts makes narrowing the wheels desirable.
Old Sep 5, 2018 | 08:08 PM
fuggles's Avatar
fuggles
Buy new rims, or live with the poke, or buy flared fenders, or don't upgrade brakes. I think these are the options. I chose to live with the poke.
Old Sep 6, 2018 | 04:57 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Sep 28, 2018 | 01:31 PM
Cruising
Duh...I totally didn't consider that. Man how stupid am I? Oh well at least I have an extra set of 18s for road racing now. LOL
Old Sep 28, 2018 | 01:40 PM
z06801's Avatar
z06801
Hey that's never a bad thing! I use to have a rear set that was widen 1" worked great. Sold them when my flares went on the rear wish I would have just keep them.
It doesn't seem like my rear 10.5" poked out that much on the front.
Old Sep 29, 2018 | 02:55 PM
KnightDriveTV's Avatar
0KnightDriveTV
Former Vendor
So, to be very clear, you've had a square setup with 295's on all four corners, experienced rubbing, rut following and traction control issues, first hand?l
I have a square setup with 295's on my daily driven Z06, that's not even stock ride height, so I'll wait for your answer.
Old Sep 30, 2018 | 09:03 AM
ATLZ16's Avatar
ATLZ16
I'm looking to move to a square 18" z06 set up on my road course z51. Anyone have any pictures of the 18" z06 on the front of the car and what size tires are you running? 295/?/18 or 305/?/18 or 315/?/18
To Narrowing rear C5Z wheels?
