Tire sensor
Old Sep 12, 2018 | 03:55 PM
corvettegt's Avatar
corvettegt
Default Tire sensor
i was driving and tire sensor pop-up mon-sys check my right rear
showed no pressure then everything was ok need help
Old Sep 12, 2018 | 04:02 PM
mrlmd's Avatar
mrlmd
How old is your car? How old are the sensors? Were they ever replaced, like when and if you've ever gotten new tires? You might just have a dead battery in that one - they may last 10-12 years or so then they poop out. If that's the case, all four will have to replaced soon. You can try and reprogram it (you'll actually have to do all 4) or if you can live with it, wait 'till you need tires and address it then.
If you get new sensors, you must get ones compatible with your specific year C5, the later ones won't work in the earlier cars.
Old Sep 12, 2018 | 08:06 PM
awches's Avatar
awches
Had my '03 do that to the left front a couple times this summer. I ordered a replacement from Walmart but it has not showed it's face again in the last 1000 or so miles.
Old Sep 12, 2018 | 10:35 PM
I agree it could be that sensor is about to go out. Good questions asked by mrlmd. Your answers could give you a good start on figuring out how to proceed.
Old Jun 3, 2019 | 05:18 PM
xltboss's Avatar
xltboss
Cruising
I'm the second owner of a 2002 coupe and have no record of that type of maintenance. I am not replacing tires any time soon but I dont have a "service tire pressure monitoring system" message on the dash. I check my tire pressure every time I drive it and it's perfect every time. Do I need to replace the TPMS units or just bring it in to a shop for some kind of service?
Old Jun 3, 2019 | 05:21 PM
DDaaryl's Avatar
DDaaryl
On my 02 vert they started to fail two years ago due to end of battery life. I waited for a tire change and replaced all the TPMS at that time.
To Tire sensor
