Radios
A Double-DIN is very nice, but if budget doesn't allow it and you want to consider a Single-DIN, then you would need an adapter plate to secure the new unit in place and provide a nice finish.
Here is an adapter plate that matches the interior very well. It has the word "Corvette" engraved in it that can be set up with backlighting (or you can customize the lettering).
From their website:
The lettering can be above or below the head unit opening, there is also a non illuminated version with the head unit located in the center of the mount.
The main lettering illumination available in red, blue, green, yellow, white LED’s and also red mini lamp illumination.
Custom lettering and design is available.
For a Double-DIN headunit you will need a Double-DIN bezel. Vettenuts offers one that is topnotch, but not inexpensive. There's a less expensive option, although not at the same quality level, from Metra. You may want to compare them before making a decision.
Regarding the headunit, these are basically the main options available:
- Replace just the headunit, leaving the rest of the system intact using
- (this one preserves the RAP feature)
- Keep the headunit, but replace everything else adding a multichannel external amp driving new speakers through new wires by using
- Replace just the 4 twiddlers with 2-way coaxial speakers leaving the rest of the system intact
- Combine 1 and 3
- Take everything out and replace all from scratch
That being said, without a doubt, the easiest and least expensive way to upgrade the system with the more bang for your buck is new speakers that can be bolted on in place of the factory ones, keeping the rest of the system intact.
The C5 OEM speakers do not include any real tweeter. Bose used 4 plain-cone (paper) speakers to handle high and mid frequencies and called them "twiddlers". That's why you can make a big improvement by replacing them with a 2-way coaxial design.
OEM C5 Speaker Sizes:
-Front
Twiddler: 3.5"
Subwoofer: 8"
-Rear Twiddler
Coupe: 6.5"
FRC/Z06/Convertible: 5.25"
For bolt-on speaker upgrades, get 3.5" 2-way coaxial speakers to replace the doors' twiddlers and 2-way coaxials of the right size for the rear. Don't touch the OEM subwoofers.
A quick search produced this:
JL Audio Evolution™ C2 Series 2-way car speakers:
- C2-350X (3-1/2")
- C2-525X (5-1/4")
- C2-650X (6-1/2")
Not only they are from the same manufacturer, but they all belong to the same line. This should reasonably assure you they have the same timbre.
You are going to need as well. One kit will do both rears.
Independent confirmation that upgrading the 4 twiddlers makes a noticeable and worthwhile upgrade.
GCG very nice write up, but I will add that I am 99% sure that the current PAC box retains the RAP as well. I will verify soon. I don't really care about that feature but I am certain I have taken the key out and the radio remains on until a door is opened.
Gunmetalblue's info about Crutchfield is good to have. I have sometimes found comparable equipment the same price or even a little lower on Amazon, but Crutchfield has a great support team that can walk you through almost any issue you're facing while installing your new equipment.
GCG's breakdown was very complete and comprehensive. However, the question he asked about double or single din is ssignificant. You need to decide that before you get very far into determining which specific pieces of equipment you'll need. As Mr. Black said, a great feature with the double din is the back up camera and WAZE. We also have a front facing camera, navigation, and very important to me is hands free telephone. We spent the extra money to go with the double din console from Vettenuts. As stated, it is more expensive than the Metra unit by about $120, if I remember correctly. However, when looking at the difference in texture (the Vettenuts bezel is virtually identical to the rest of your dash), to me the cost difference spread over however many years we keep this C5 became a very minor point. Hopefully if you go the double din route you would have a chance to see both bezels so you can make your own decision.
We used a pop up single din radio that became almost as large as the double din screen however, when up it blocked the center air/heat vents and it wouldn't interface with our Apple iPhones for nav or hands free. The radio/CD/MP5 player would work when the screen was down however, it became a hassle to remember to raise it every time we wanted to see the back up camera. My grandson is very pleased we went with a new system since he inherited the Panasonic unit.
Best wishes with your search!
Is that a big deal and do you have to have the new bezel? Thanks, John
If you install a 'digital receiver' (deck with AM/FM, MP3, USB HD radio, Bluetooth, Handsfree, Pandora, SiriusXM... and NO CD player), there is no need to modify the bracket because they are not as deep. Who uses CD's anyway.
If you install a 'digital receiver' (deck with AM/FM, HD radio, Bluetooth, Handsfree, Pandora, SiriusXM... and NO CD player), there is no need to modify the bracket because they are not as deep. Who uses CD's anyway, it's not 2002 anymore!
- Axxess XSVI-2004 (this one preserves the RAP feature)
- Pac Audio ROEM-VET1
- Combine 1 and 3
Since the doesn't interface with the Serial Data Bus, it doesn't preserve RAP and requires the extra switched connection. The headunit's OEM harness lacks this connection, but it can be easily brought from an unused harness (except '04) in the passenger's footwell that has ground, always hot and accessory switched wires with separate fuses.
