The dreaded flat spots!
Old Oct 3, 2018 | 02:42 PM
02BlownZ06's Avatar
02BlownZ06
Default The dreaded flat spots!
I have had nothing but good to say about the Hankook Ventus tires on my Z06, but recently I started getting a vibration at road speeds so I thought a tire out of balance. I took it in and had them balanced and the tech is telling me I have flat spots and that one tire in road force test has a hard spot on it. UGGHH! Have any of you experienced this? This is not my daily driver but I usually stretch her legs almost every weekend. Do I have to store the dang thing on Jackstands when not using or what???
Old Oct 3, 2018 | 03:29 PM
glbeauchamp's Avatar
glbeauchamp
I took a 1 1/2" thick sheet of pink styrofoam and cut it into 2ft X 8 ft lengths and secured them to the garage floor with duct tape where the wheels are when the car is parked. After a while (weeks) the tires settled into the styrofoam and it supported the bottoms of the tires like those tire dollies that cost about $40 each. Of course the sheets don't have wheels so the car can't be moved around but they seem to serve the purpose to keep the tires from getting flat spots..
Old Oct 3, 2018 | 05:04 PM
Obviously a problem could develop with any tire, but I have been running Hankooks for years and not had a hard spot develop. My car does sit for extended periods and has shown some flat spotting when I drive it again, but that usually works itself out after a few miles of driving.
Old Oct 3, 2018 | 05:59 PM
DDaaryl's Avatar
DDaaryl
Two years on my vert, no flat spots, stored a few months and only driven 2,000 miles a year
Old Oct 3, 2018 | 06:04 PM
bc6152's Avatar
bc6152
I would agree with Vetteman. My '66 sat for weeks and when I got a chance to drive it I would have flat spots, but they would disappear within a few miles when the tires heated up.
Old Oct 3, 2018 | 06:15 PM
6speedsteve's Avatar
6speedsteve
I run Nitto Invo's I get flat spots, but not all the time, It is annoying but they always go away.
Old Oct 3, 2018 | 07:06 PM
3sACROWD's Avatar
3sACROWD
As far as I know, flat spots on a radial tire is fairly rare. Bias ply tires were prone to it are they sure you didn't separate a belt? It could be a defective tire.
Old Oct 3, 2018 | 08:18 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
Old Oct 3, 2018 | 08:23 PM
regalvette's Avatar
regalvette
I haven't had any flat spots in several years of running on hankook tires, but I keep the car parked on a double layer of carpeting under each wheel.
Old Oct 3, 2018 | 08:35 PM
6speedsteve
I think it may also have something to do with the compound of the tire, Hankook & Nitto are foreign made tires, I also have Nitto NT420S on my truck & are noticeably stiffer when cold or if my truck sits for a few days.
Old Oct 3, 2018 | 09:04 PM
JR-01's Avatar
JR-01
It is rare, but I have had flat spots on modern radials after 6 month storage. Over inflating them must help, since I haven't had a flat spot since I started doing it.
Old Oct 4, 2018 | 07:39 AM
Simtech's Avatar
Simtech
I just drive mine everyday . 3rd set of rear Hankooks put on yesterday. I did find that if a run them at 30 psi it wears the centers out faster than the edges, I dropped them to 28 and they seem to wear more evenly.
To The dreaded flat spots!
