under hood engine light
Old Oct 10, 2018 | 04:10 PM
rayz1951's Avatar
rayz1951
Default under hood engine light
How do you remove the cover to the engine bay light? I've been trying to get it off but it doesn't want to budge and I don't want to break it. Does it only go on when you open the hood at night or in the daytime too? I want to change the bulb to led. It never worked since I bought the car a couple of years ago.
Ray Z
Old Oct 10, 2018 | 05:55 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
There are a couple of tabs on the lens (cover), that engage a couple of slots in the lamp housing. You squeeze the sides of the lens, and this disengages the tabs, then gently pull the lens from the housing.
Old Oct 10, 2018 | 07:22 PM
o2bnkc's Avatar
o2bnkc
The light comes on when the hood is opened, day or night. If it's never worked, make sure it's plugged in. It should be plugged in on the passenger side, lower front, if I remember correctly.
Old Oct 10, 2018 | 09:03 PM
gaustins11's Avatar
gaustins11
My hood light didn't work and discovered it was a blown fuse (also runs the vanity lights).
Old Oct 10, 2018 | 11:22 PM
shaggyvette's Avatar
shaggyvette
St. Jude Donor '10-'11-'12, '19, '21
I put a switch on mine, even though it goes off after 15 minutes.
Old Oct 11, 2018 | 12:06 AM
This. Be careful when squeezing the lens cover - after all this time it could be brittle.
Old Oct 12, 2018 | 08:45 AM
rayz1951's Avatar
rayz1951
Thanks for the info. I took apart the plug and cleaned the terminals, plugged it back in and it works.
To under hood engine light
