Corbeau a4 seat install
Old Nov 2, 2018 | 10:59 AM
tommypenguin's Avatar
tommypenguin
Default Corbeau a4 seat install
In the process of doing the install. Couple of notes that might be helpful to others. Don't order corbeau seat brackets from summit, or anywhere other than corbeau unless your sure they have double sliders. I ordered from summit and have to return them because they showed up with single sliders.
Second I redrilled the seat brackets per toques install thread, it is a VERY tight fit.
I had to bore out two bolt holes on each seat bracket form it to fit on the seat studs.
Lastly don't forget to cut the little tang on the seat belt receiver so you can rotate the receiver in a position that makes it feel like stock when buckled down. I need to do that today. In the midst of a few projects on the car will post back with feedback on how the seats feel in a little bit.
Old Nov 2, 2018 | 12:19 PM
chris308's Avatar
chris308
thanks for the tips
Old Nov 2, 2018 | 03:36 PM
Thank you for sharing those install tips. They are sure to help out others considering the Corbeau a4 seats.
To Corbeau a4 seat install
