Replacement Suspension Bushing Kits
Old Jan 21, 2019 | 03:32 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Default Replacement Suspension Bushing Kits
Can anyone with some experience educate me on what the best options are for replacement bushing kits? I've seen several kits with varying prices, but I don't know what the difference is.
Old Jan 21, 2019 | 04:45 PM
Toys4Life C5's Avatar
Toys4Life C5
St. Jude Donor '21
I am with Chris on this question and would also appreciate some good HONEST feedback from those who have first hand experience. With the upped HP level of the A&A kit, the rear rubber is giving me wheel hop under certain temps/traction conditions. Poly (from other vehicles I have) can be annoying and squeeky if not lubed with poly grease every year or so - so I am hoping there are better options??
b/t/w - Chris - I am subscribed to your Youtube channel and enjoy it! Please check out mine -Toys4Life C5. Of course it is mainly Corvette stuff - mods.
Ken
Old Jan 21, 2019 | 08:03 PM
493lszosix's Avatar
493lszosix
I have Delrin control arm bushings front and rear and am very happy with them, no movement like the stock rubber bushings and no noise, car is lowered and still rides good
Old Jan 21, 2019 | 09:22 PM
Toys4Life C5
St. Jude Donor '21
How long have you had them and or approximately how many miles - ballpark?
Old Jan 22, 2019 | 12:05 AM
493lszosix's Avatar
493lszosix
just guessing probably around 6-8 months, maybe 3-5000 miles
Old Jan 22, 2019 | 06:23 AM
FR-CYA's Avatar
FR-CYA
Did you have to drill and tap your control arms for grease fittings to run Delrin bushings? What brand bushings? Where did you buy? You mention the ride is good. Was there a noticeable difference between pre and post install?
Really appreciate the feedback here. I’m in the same boat as Chris and others. Contemplating an upgrade for my control arm bushings and not sure what to do yet. Delrin vs Polyurethane vs stock rubber. Car will see a few HPDE days this season and is driven less than 5000 miles a year.
Old Jan 22, 2019 | 10:04 PM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Vansteel will rebuild yours for a reasonable price, or rebuild yourself if you're up for it.
Old Jan 23, 2019 | 12:41 AM
493lszosix's Avatar
493lszosix
[QUOTE=FR-CYA;1598734832]
I don’t have any grease fittings, I think they are the Van Steel brand, I was going to buy the kit off ebay then happened accros someone selling a brand new already installed kit with front and rear control arms included, they had shipped them off and had them professionally installed so I bought them since all I had to do was install them. The biggest difference is the rubber bushings have lots of flex, these are like a solid bushing with zero movement but amazing the car still rides good, it’s lowered with front bolts removed, I street/drag the car
Old Jan 23, 2019 | 08:31 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Just my $0.02 worth....
I've been using Polyurethane bushings in various cars that I've owned, since they first started appearing in the late 1970s. My first set was for a Firebird that I had at the time, and they were a "generic" bushing that I purchased from the former Pontiac supply house, "H-O Racing Specialties". They appeared to be a rather "stiff" composition, and while they did truly tighten up the suspension, they squeaked like crazy, after a while. And back in those days, lubrication technology hadn't yet caught up with these bushings, so the noise got annoying, with no cure.
A couple of years later, 'Energy Suspension' came along, with better product formulations, which along with better lubricants, provided a much better experience. HOWEVER, here's where I suggest being cautious. I continued to be a fan of the poly bushings, BUT living in an area where the roads are far from stellar, as tire sidewalls got shorter and shorter, the added stiffness of the poly bushing became a liability. I eventually had a Z/28 Camaro in my personal fleet, into which I installed a set of the poly bushings. The shorter, stiffer sidewalls of it's tires, combined with the non-compliance of the poly bushings, on the crappy roads, made for a bone-jarring ride. That was the first car, of many of those that I had previously installed poly bushings in, that I actually removed the poly parts from, and went back to rubber bushings.
My conclusion is yes, poly bushings do work, and do improve the suspension response, but at a price. If you live where the roads are marginal, I suggest that you think twice before installing them. If the bushings in your car have gotten "squishy", possible new rubber bushings would be a good compromise.
Old Jan 23, 2019 | 08:43 AM
Toys4Life C5
St. Jude Donor '21
Thank you for the real world first hand experience well though out response.
We do need to seriously look at where we drive the car 99% of the time and carefully evaluate the trade offs.
Old Jan 23, 2019 | 03:26 PM
Chris Draper
I'm looking for what the best kit to buy is. I've read great things about the VBP kit, but VBP has apparently gone out of business recently.
What is the next best complete kit?
Old Jan 23, 2019 | 03:36 PM
FR-CYA's Avatar
FR-CYA
Chris, I'm following your lead on this one. I expect a YT "how to" video in the next month!
Old Jan 23, 2019 | 05:22 PM
gimp's Avatar
gimp
I'd love to get new rubber bushings. Alas, as far as I can tell, the only option for that is to get a full set of new control arms, as I have not found anyone claiming to sell rubber bushings individually that can be pressed in. And a set of new control arms is like $2200.
Do you have any better solutions for rubber bushings than I've found?
To Replacement Suspension Bushing Kits
