Stereo double din
Old Feb 4, 2019 | 07:29 PM
DIABL0's Avatar
DIABL0
Default Stereo double din
is there a vender who sells kits for a double din with stereo an harness package?
Old Feb 4, 2019 | 07:55 PM
DIABL0's Avatar
DIABL0
Old Feb 4, 2019 | 09:01 PM
Tenshots1's Avatar
Tenshots1
Keep in mind that you can find the metra bezel for $190 and the DEM converter for $35 on amazon. That leaves you to be able to get whichever head unit you want. Problem with the metra bezel is that the paint and texture do not match factory. You can paint to match, but i havent found a write up of which paint and texture match the best.
But, I would also be interested in knowing who sells bezels from this forum. Sadly Double D stopped.
Old Feb 4, 2019 | 09:28 PM
mmo24's Avatar
mmo24
Try these.
Amazon Amazon
Old Feb 4, 2019 | 10:11 PM
VetteNuts sells a double din bezel that looks like a good match, finish wise, to the rest of the interior panels.
Old Feb 5, 2019 | 01:27 AM
GCG's Avatar
GCG
You can create your own Double-Din upgrade package for less money, or with better components.
Vettenuts offers a Double-Din radio bezel that is topnotch, but not inexpensive. There's a less expensive option, although not at the same quality level, from Metra. You may want to compare them before making a decision.
You can use either one of these adapters:You will just need to add the mounting brackets for the headunit and the antenna adapter to the headunit of your choice to complete the package.
To Stereo double din
