battery run down
Old Feb 8, 2019 | 09:11 PM
walleyejack's Avatar
walleyejack
Default battery run down
does the 2002 C5 have battery run down protection ? if you leave the hatch popped or a door open, the light is on, and if you don close things up, battery will drain for 15 min and then automaticly shut down. Like the C6 and C7. did a search and in stickies, i see nothing.
tia
Old Feb 8, 2019 | 09:36 PM
Forcedvert's Avatar
Forcedvert
Seems like mine does...... but someone will chime in that knows for sure.
Old Feb 8, 2019 | 11:39 PM
walleyejack
mine didnt.. left the hatch popped the other night and flatter than a pancake the next day.
am just returning to the C5 world after leaving in 2009 for the C6 and C7. Am happy to be back for sure.
Old Feb 8, 2019 | 11:45 PM
El original's Avatar
El original
My 2003 does have it!
Old Feb 9, 2019 | 09:19 AM
walleyejack
I should have been more specific, 2002. My mistake
Old Feb 9, 2019 | 09:52 AM
Forcedvert's Avatar
Forcedvert
ftr mine is an ‘01 (seems to do it)
bttt for a firm answer for ya.....
Old Feb 9, 2019 | 10:38 AM
Yes, the car does have a battery run down protection. I know my ‘99, ‘00 and ‘03 all had that feature. It should say it in the owner’s manual.
Old Feb 9, 2019 | 12:08 PM
b_rad!'s Avatar
b_rad!
Al glad to hear you found a C5! What car did you finally settle on? Z06?
Old Feb 9, 2019 | 08:02 PM
walleyejack
is there any other Brad ???
thank you for your help sir. i appreciate it.
Old Feb 11, 2019 | 12:19 PM
reneeautumn's Avatar
reneeautumn
went thru 3 red top bat...then switched to deep cycle yellow top ...meant to be charged but more important put a battery shutoff for less than $5.00 ...and just turn the shutoff **** off when I'm done driving and no more dead batteries...battery will be 6yrs old in april and still at 12.7 to 12.73 whenever I check it...give it a charge now once a yr. with my ctek charger. Drive my car once a week or less. Hope this info helps someone...cheers...my ride is 99 modded 641 rwh
Old Feb 11, 2019 | 08:42 PM
walleyejack
seems to work now,, not sure what happ the first night in my garage, left the hatch open dead in the morning. Been messing with stuff most every day with the door open and it shuts itself down after 10 or 15 minutes.
thanks for the input folks.
To battery run down
