Question pertaining to the clock spring
Old Feb 15, 2019 | 01:40 AM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Default Question pertaining to the clock spring
I'm replacing the clock spring on my 98.
I have found 5 part numbers for 97 thru 04.
There are two listed for 97 98. Three listed for 99 thru 04.
I purchased one off ebay. When I got the one off my car the numbers don't match.
Does the numbers have to match? What's the difference between the numbers?
Thanks.
Old Feb 15, 2019 | 02:38 AM
WICKEDFRC's Avatar
WICKEDFRC
I had a 2000 C5 FRC and never heard of a clock spring.
What is it?
Old Feb 15, 2019 | 03:12 AM
Vette97sc's Avatar
Vette97sc
Clock spring is airbag part in steering wheel. I change clock spring to my -97. I buy 97-98 clock spring from ebay. It look just same in pics but when i get clock spring i see connector was abit different. I take connector from old clock spring, put it to new one and then airbag light shut down.
Old Feb 15, 2019 | 06:38 AM
cvm's Avatar
cvm
What is it?
clock spring is what the import crowd calls a 'steering wheel position sensor'
signals to ABS/TCS/Active handling modules not SRS.
I never heard of it either till I went to wrench at a Honda dealership.
OP do not use wrong part even if connector is same, or at least I would not personally.
Old Feb 15, 2019 | 07:39 AM
Vette97sc's Avatar
Vette97sc
Steering wheel position sensor and clock spring is not same thing. Swps locate in steering column near firewall and clock spring end off steering column.
Old Feb 15, 2019 | 09:27 AM
VFR RC46's Avatar
VFR RC46
The Clock spring contains a wound up wire that plugs into the air bag and allows the steering wheel to turn freely. They are notoriously week in c5s.
Old Feb 15, 2019 | 09:37 AM
Sydwayz's Avatar
Sydwayz
St. Jude Donor '18
Originally Posted by vette97sc
steering wheel position sensor and clock spring is not same thing. Swps locate in steering column near firewall and clock spring end off steering column.
truth.
Old Feb 15, 2019 | 10:41 AM
I had heard of the clock spring but never seen one. Thanks for the pics.
Old Feb 15, 2019 | 11:32 AM
Josephu's Avatar
Josephu
What he said!!
Old Feb 15, 2019 | 12:23 PM
Gordy M's Avatar
Gordy M
With a used clock spring make sure it is properly centered before you install it, most reputable resellers will center it before they sell it but many on the market were as the wheels were pointing when they took it off. There is a separate method of centering them on google that you can use.
To Question pertaining to the clock spring
