Date Code on Tires
Old Feb 25, 2019 | 01:27 PM
DNAST1's Avatar
DNAST1
2025 C8 of the Year Finalist - Modified
2023 C5 of the Year Winner - Modified
2023 Corvette of the Year Finalist (C8) - Modified
2023 Corvette of the Year Finalist (C6) - Modified
2022 C8 of the Year Winner - Modified
2022 C6 of the Year Winner - Modified
Default Date Code on Tires
Hello, I came across a good deal from a tire vendor online to replace my 8 year old tires. When I asked what the date codes are on the tires he could only guaranty that they were manufactured in the last 3 years; 2017-2018 probably he said. Is that normal when buying tires from a distributer? Thanks
Old Feb 25, 2019 | 01:42 PM
Velocity_Vette's Avatar
Velocity_Vette
I guess by "normal" your asking if this is ethical or do every tire carrier check the date codes on their tires?
One thing you need to remember is most people that buy tires do not see them through the full date cycle of their life; they'll see the full wear points before they hit anywhere near close to their optimal date range of five to six years when a tire should be replaced regardless of tread left. Thus for the majority of shoppers a tire that has been stocked for the past year or so is ultimately not a huge deal.
For a car like a Corvette where most people are not going to see full mileage but will see a tire's full life span, it can be concerning. You do not want to buy a tire that has a manufacturer date of three years old if you only put like 5,000 miles a year on your car as you'll be replacing those tires in about three to four years when they've hit their optimal date life well before their mileage life.
My suggestion would be to check the vendor's return policies and see if it is possible to return a tire if it is a few years old shelf life'd prior to receiving. My immediate guess is there would be a return stock fee and subsequent shipping fee; something you may need to seriously consider if this is actually a good "deal" or could you pay a little more from a local supplier knowing you'll get a tire with a more suitable production date.
Old Feb 25, 2019 | 02:54 PM
DNAST1's Avatar
DNAST1
Thanks! Good information to consider!
Old Feb 25, 2019 | 03:07 PM
grantv's Avatar
grantv
It might be "normal", never bought other than from a local tire shop. I can see why though...
You call today looking for tires. 3 others also. They give actual dates from the first tires available to all 4, but Bob in PA buys b4 you. Now you don't get what was said.
Old Feb 25, 2019 | 06:40 PM
knewblewkorvette's Avatar
knewblewkorvette
For how many tires I've purchased over the years, I've never checked the year they were produced. I just took it for granted they were made that year or the year before. I know I had to replace the fronts on my 02 even though they had allot of tread left on them. They were like 10 years old. I replace the rears more often so they don't get to that point.
Old Feb 25, 2019 | 07:47 PM
1999corvettels1's Avatar
1999corvettels1
What happens with old tires but good tread, blowout?
On my 1965 C10 I bought new Goodyear's for all 4 wheels in summer 2002, it hasn't been driven much, most was northern California to Texas when moving, then Texas to Arizona.
I guess I better buy new tires when I start driving it again.
Old Feb 25, 2019 | 08:12 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
The chances of blowout are definitely increased by how old they are. Rubber over time gets hard and brittle, and that's the last thing you want for a tire compound during inclimate weather, let alone normal driving conditions. Replace those babies pdq.
Old Feb 25, 2019 | 08:19 PM
USRobo's Avatar
USRobo
The date code is on each tire usually near the DOT number the date code is in weeks and years. So if you see 0819 that means the tire was manufactured the 8th week of 2019. If it says 2218 that means it was built the 22nd week of 2018.
Old Feb 25, 2019 | 11:02 PM
1999corvettels1
I went out and looked with a flashlight and on 2 tires could not find date codes, however I did see what I think are some age defects, a ridge that looks like it will rip open one day on front driver's side, rear driver's side didn't have it.
I will definitely get new tires when it's insured and registered again.
Old Feb 25, 2019 | 11:05 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
all tires have date codes....most retailers sell stuff that is made within the last year, usually last 6 months depending on the popularity of the specifis tire and size....I always check
Old Feb 25, 2019 | 11:34 PM
This. I have had good luck with a local tire store price matching Internet quotes for tires and that way I can easily control whether the date codes are acceptable or not. I state up front that I will not accept tires older than a certain manufacture date.
Old Feb 26, 2019 | 07:09 AM
USRobo's Avatar
USRobo
I just bought some tires a week ago from SummitRacing. The date code is in the little box (0519) Fifth week of 2019. All tires should have this someplace on the tire.
Old Feb 26, 2019 | 08:05 AM
roadbike56's Avatar
roadbike56
St. Jude Donor '16-'17,'22,'24
If you have OEM tires on a 99 C5 then the date code will not follow the format being provided by others on this thread. Prior to year 2000, the date code was embedded in the serial number. It should be the last three digits in the serial number. You will not find a separate date code on pre 2000 tires. Also, that means they are ancient and should not be used.
Old Feb 26, 2019 | 08:34 AM
1999corvettels1
Sorry, I meant the tires on my 1965 C10, that I bought summer 2002, Goodyear from America's Tire (what Discount Tire is called called in California)
Will try looking again in daylight.
Old Feb 26, 2019 | 03:15 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Tires should be changed every 6 years or so depending on driving and road conditions.
Old Feb 26, 2019 | 05:59 PM
knewblewkorvette
Sometimes the date code is only on one side of the tires like my Michelin tires.
Old Feb 26, 2019 | 06:11 PM
1999corvettels1
I was wondering about that.
Old Feb 27, 2019 | 07:01 AM
ZigZag's Avatar
ZigZag
If you couldn't find date code on the outside then it will be on the inside, unless they're extremely old.
To Date Code on Tires
