Optima 400 Charger?
Old Mar 3, 2019 | 11:11 AM
royal flush's Avatar
royal flush
Default Optima 400 Charger?
anyone use this unit--pros and cons--Does the message center light stay on all the time?
Old Mar 3, 2019 | 11:47 AM
50thz06's Avatar
50thz06
I've had one for about a year. I'm pretty happy with it. Pros: it works, it has the ability to do minor charging and maintains charge quite well. My Optima red top seems to like it. I've used it in other batteries as well and it works great to keep a battery fully charged.
Cons: once when I had a power failure, when power returned it switched back on as "small battery" so if you have a power failure just check it. Small battery setting wouldn't have hurt anything in this case, though. The backlighting turns off after several minutes, but I have noticed that if I walk in the shop to check the charger and turn on the backlighting, it "wakes the charger up" briefly and it goes to a moderate charge level for a couple minutes.l, then back to maintain. Kinda funny actually, its like it "got caught sleeping on the job." I'm not really impressed with the battery clamps though. The charger came with a hard wire with connector option but I've just been using the quick clamps and their kinda cheap. I'll probably upgrade them at some point or just hard wire it. Overall I'm happy with it. However, it won't charge a lithium iron battery. My bike has one and I had to buy a special charger just for it.
Old Mar 3, 2019 | 12:07 PM
royal flush
Thx for the response--when battery fully charged and in maintance mode--you can see the voltage going to battery on the message center?
Old Mar 3, 2019 | 12:55 PM
50thz06's Avatar
50thz06
Yes as long as you don't turn the backlight on it will tell you the current condition and maintenance charge rate. You can see it without the backlight. If you turn on the backlight the charger ramps up for a couple minutes and may not be dead accurate for current condition.
Old Mar 3, 2019 | 01:22 PM
royal flush
Sounds like to me--when you turn the backlight on the charger the charger draws juice and thinks it the battery dropping-voltage--a quirk----are all the lights bright enough to see from 10-15 feet?
Old Mar 3, 2019 | 02:09 PM
50thz06's Avatar
50thz06
Lights are easy to see across the room. You can tell pretty easy if battery is 100%. As far as reading the voltmeter you'd need eagle eyes but I don't personally have a problem with that.
Old Mar 3, 2019 | 02:15 PM
royal flush
Thx again--im going to order the 400--one more thing--what does the unit read for volts when in mintance mode? im guessing around 13.40s
Old Mar 3, 2019 | 02:38 PM
50thz06's Avatar
50thz06
In my case most of the time it ranges from 12.9 to about 13.1 when it's just idling, but I've sent it idle as high as about 13.4 to 13.5. I suppose it depends on current draw in the car, etc. Idle meaning it's not actively maintaining. When it's trickle charging it can go close to 14 at times, again probably depends on car and battery.
Old Mar 3, 2019 | 04:18 PM
royal flush
-------does the 400 show when its fully charged what voltage and amps is going to the battery?
Old Mar 3, 2019 | 04:31 PM
knewblewkorvette's Avatar
knewblewkorvette
I have had the 1200 since it came out. Very nice piece of equipment.
Old Mar 4, 2019 | 08:47 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I've had one for about 6-7 years, and am very happy with it.
To Optima 400 Charger?
