Adhesive Remover
Old Mar 6, 2019 | 03:59 PM
StocktonC7GS's Avatar
StocktonC7GS
Default Adhesive Remover
Looks like the PO had installed some kind of weatherstripping and removed at some time. The residue is hard as a rock. What can be used to help break this stuff down and eventually remove without damaging the paint? Goo Gone....WD40....?
Old Mar 6, 2019 | 04:10 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I swear by 3M Adhesive Remover. Spendy but TOTALLY worth it.
Old Mar 6, 2019 | 04:49 PM
Velocity_Vette's Avatar
Velocity_Vette
That's not typically an ideal area for weather stripping because of the front fascia bolts there. You usually want to install it along the curvature of the fascia opening so the hood sandwiches it when closed. I'd surmise it may have been some sort of thing for a fascia cover or bra, like a holder or thing that holds clips.
Goo Gone or WD-40 would probably take it off (I've removed stuff like that on paint plenty of times with WD-40). It does need to sit for a while. Then use a good squeegee like ET said.
Old Mar 6, 2019 | 05:04 PM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
Naptha at Home Depot in the paint department....cheap...won't harm your paint.
Old Mar 6, 2019 | 05:37 PM
knewblewkorvette's Avatar
knewblewkorvette
My 98 had that, Velcro was there to hold on bra.
Old Mar 6, 2019 | 05:50 PM
ALLEGRO's Avatar
ALLEGRO
WD 40 always works but is a mess to remove itself sometimes.
My "go to" product is Goo Gone. It works on most everything, easy to remove the product and seems to work on most every adhesive and on most every surface.
You won't be sorry.
Old Mar 6, 2019 | 08:13 PM
StingrayRebel's Avatar
StingrayRebel
I would use your finger to roll it off as opposed to using your nail or a plastic tool, if you press too hard you will leave lines imprinted in the paint... if it's too difficult to remove it that way when dry then use some wd40 or goo gone to soften it up
Old Mar 6, 2019 | 09:59 PM
Ed Ramberger's Avatar
Ed Ramberger
I would try goo gone and a plastic razor blade. Goo Gone is really good and the plastic blades don't harm paint.
Old Mar 6, 2019 | 10:09 PM
FYRARMS's Avatar
FYRARMS
I tossed out my bottle of Goo Gone after using Rapid Remover for the first time. This was recommended to me by a professional detailer. This stuff works in the same fashion as Goo Gone, but it just works much better. I was able to easily remove all of my Z06's factory badges, and I was also able to remove old 3M trim adhesive, which some people said I wouldn't be able to do.
Old Mar 7, 2019 | 12:56 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
if that doesn't work you can always try this...
Old Mar 7, 2019 | 05:38 AM
Ed Ramberger
thanks. Always looking for good tips.
Old Mar 7, 2019 | 06:03 AM
wscott62893's Avatar
wscott62893
I agree! 3M also makes an adhesive removal drill attachment that is magical. Also a bit pricey but you can use it a bunch of times and it is a million times easier then soaking/scrubbing with other available options.
Old Mar 7, 2019 | 08:20 AM
StingrayRebel
if you are talking about that eraser wheel that goes on a drill be very careful on plastic parts... it gets hot pretty quick and will heat up the plastic and rip the paint right off, works good on metal though but you will always have to go over the area with some type of solvent to get remove the leftover residue
Old Mar 7, 2019 | 08:26 AM
wscott62893
Good point! It's still a viable option that I've had success with on both plastic and fiberglass body panels in the past. But it surely requires some finesse to get the results you're looking for. Low drill RPMs and patience!
Old Mar 7, 2019 | 09:43 PM
Georgies's Avatar
Georgies
Ronsol lighter fluid is great. Opticians use it daily on high end lenses and sun glass frames. Works well, and its cheap.
Old Mar 8, 2019 | 12:26 AM
StocktonC7GS
OK, followed ET's advice....soaked some paper towel with Goo Gone....applied this morning....12 hour soak....and whaddya know....Goo Gone! Just a bit of haze that will most likely buff out. Thanks everyone!
Old Mar 8, 2019 | 12:58 AM
StocktonC7GS
Perfect...thanks ET!
To Adhesive Remover
Old Mar 8, 2019 | 02:45 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
"I highly recommend this stuff..."
Old Mar 8, 2019 | 06:28 PM
Georgies's Avatar
Georgies
Try Ronsol lighter fluid. Removed the door molding adhesive that was there since 2003. Took a bit if time, but the stuff costs 3$ and doesn't leave any haze. I will try a bottle of rapid remover. Just a note id rather take more time and do less damage to the paint.
Old Mar 8, 2019 | 11:55 PM
Glad you got it off without too much trouble. Good recommendations for what to use here.
