Jacking a C5
Old Mar 9, 2019 | 07:45 AM
Ramets's Avatar
Ramets
Default Jacking a C5
I'm getting ready to pull my wheels to do a proper cleaning of the barrels and need some info. I see on the web a lot of posts about jacking up the entire back, or front. I just want to do one wheel at a time. I have a low profile floor jack and pucks installed, but I don't have any jack stands. Is a jack stand necessary when jacking up just one wheel?
Old Mar 9, 2019 | 08:05 AM
DDaaryl's Avatar
DDaaryl
Nope
Old Mar 9, 2019 | 08:37 AM
roelkers's Avatar
roelkers
No but for safety reasons it’s always better to have a jack stand underneath just in case someone accidentally bumps the jack.
Old Mar 9, 2019 | 09:25 AM
run1fsr's Avatar
run1fsr
Safety First
Old Mar 9, 2019 | 09:29 AM
bikemiser's Avatar
bikemiser
I find you can't jack just one wheel, two wheels are off the ground no matter what.
Old Mar 9, 2019 | 09:35 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Yes a jack stand is necessary when lifting one corner. Place the jack stand under one of these jacking locations:
You should always use jacking pucks when lifting from the frame contact hoist locations if you don't have frame rail protection.
Old Mar 9, 2019 | 09:49 AM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
You should have a horrible fright store near you. Go there and get some. You should have them anyways.
Old Mar 9, 2019 | 11:31 AM
Gordy M's Avatar
Gordy M
For safety you should use jack stands, with the right tools you probably will not use them. If you have a lightweight jack and puck in place you can lift the one side completely off the ground from the front jacking point. If you have an impact gun and have done it hundreds of time you can have the nuts off, wheel off and new wheel on and tighten them to about 80 lbs in three minutes. If the jack were to let go the C5 is very rigid and will still hold up on three wheels. Since you are not under the car at any time you will be safe. However you first few times it will take longer and if you have battery operated impact--my 20 yr old HF--you can tighten them to the max and it will be almost 80 ft-lbs. Let the jack down so the tire will not rotate but not completely down and then torque the lugs the rest of the way. Jack up again and do the rear tires. If you go to an autocross meet or HPDE you will see this done numerous times throughout the day.
Old Mar 9, 2019 | 12:03 PM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
Obviously any time the tires are off the ground it is safer to use jack stands. They are pretty inexpensive for the peace of mind. Plus, once you start taking off wheels, you will most likely advance to other components under the car. Get the jack stands.
Old Mar 9, 2019 | 03:04 PM
3sACROWD's Avatar
3sACROWD
I agree. A jack should be viewed as a lifting device not a holding device. As stated, you will pull the wheel and clean it. Then job creep steps in and you're brushing brake dust off the caliper. Then, then, then.... All the while you're now potentially under the car that isn't supported by jack stands.
It takes a couple of minutes to get the jack stands out and in place. It takes a second to change your life forever by skipping a step.
If you don't have jack stands at least put something under the car that will support the weight if the jack comes down. Could be a stack of 2x6 boards, a wheel from another vehicle, a log, etc.
Old Mar 9, 2019 | 04:30 PM
Glasact's Avatar
Glasact
One word that sounds like two QuickJack!
Old Mar 9, 2019 | 05:25 PM
Mr. Black's Avatar
Mr. Black
Once you go quickjack you'll never go back!
Old Mar 10, 2019 | 10:30 AM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
The right tool for the right job. Ok back in the day when money was tight I would use a cinder block as last resort. Keep in mind besides the damage to your vettte
if your jack fails you could get pinned under the car or the very least lose a finger.
Good luck.
Old Jun 10, 2023 | 07:24 AM
derbs24's Avatar
derbs24
This works well when you need to pull a wheel: “use the official lifting location and place a jack stand at the control arm attachment as a safety stop. Lower the jack so the control arm attachment just touches the stand but leave the majority of weight on the jack.” I never trust a jack, but it’s never failed either.
I just did the engine/trans oil and filters and backed the car up on ramps for when I don’t need to pull a wheel. I still put jack stands loosely under the control arm pivots as an added safety measure when I’m lying under the car. I don’t care what the ramps are “rated for”, hard for me to trust my life to plastic ramps.😉 100% sure the car will support itself at the control arms (if needed) as I do this on other cars.
good luck!
Oil change set-up
Old Jun 10, 2023 | 04:41 PM
redzg's Avatar
redzg
It only takes one time of a car shifting on the jack, even if you are not underneath, to convince pretty much anyone to use a stand (or cinder block) every time.
Old Jun 11, 2023 | 02:44 AM
RogerZ06's Avatar
RogerZ06
$20 at walmart for 2 jackstands.
Old Jun 11, 2023 | 08:42 AM
60 SHARK's Avatar
60 SHARK
Exactly,,,, use something substantial, for just in case.
Even though I've never had any jack fail on me in 50yrs of playing with vehicles, its good to be prepared. You'll want to enjoy the car later, not repair more stuff on the car or on yourself, ,
To Jacking a C5
Old Jun 11, 2023 | 10:21 AM
redzg's Avatar
redzg
Originally Posted by 60 SHARK
Even though I've never had any jack fail on me in 50yrs of playing with vehicles, it’s good to be prepared.
I have. It’s definitely a “Bring me my brown pants” situation.
Old Jun 11, 2023 | 01:57 PM
c5arlen's Avatar
c5arlen
🤨 Some folks just plane don't deserve to drive Corvette.
Old Jun 11, 2023 | 08:20 PM
toms silver 60's Avatar
toms silver 60
This is an old post, but the recent replies got my interest. First time ever for having to jack the car up. I resolved the jack/jack stand "challenge" by placing appropriate 4X4 and 2X4 under the floor jack lifting points. The hydraulic jack would naturally bleed down after a while (as compared to a scissors jack) . Next time around I will cut 4X4 to desired height instead of using two blocks. BTW, the rigidity of the frame was very impressive when lifted in just one corner!
