Just bought a new shift **** that has the following adapters/size with it: M8 x 1.25, M10 x 1.5, M12 x 1.25
I have a Hurst short shifter which runs the 3/8-16 thread size.
Problem is, those numbers mean nothing to me
Can anyone point me in the direction of an adapter that'll fit between these sizes, or possible Home Depot/Lowes will have them (probably not very sightly, but I'll just paint it)
Problem is, those numbers mean nothing to me.
Thanks in advance!
Those are typical import car shifter thread specifications. As was said above, go back to the supplier to try to get an adaptor. Not a hardware store item - too specialized.
M10 x 1.5 means a 10 mm diameter thread, with a pitch (thread to thread) of 1.5mm.
3/8-16 means a 3/8 diameter thread and 16 threads/inch or 1/16" thread to thread
Google will find inch/mm conversions for you - easier than digging out the calculator!
Decided I'm just going to return it because the company doesn't make adapters for American sizes and I don't wanna deal with drilling out one of the included adapters and stuffing the right thread down there. Anyone have any recommendations for a straight black handle racing shifter that'll fit the 3/8-16 on a Hurst?
Have you checked with Hurst to see if they offer a **** in the style you want? Maybe other companies that make aftermarket shift ***** will have them in the thread size/pitch that will fit.
I use the traditional Hurst ball handle and I really like it as I can grip it with my entire hand. There's even enough area that for upshifts to 3rd and 5th, I can just push it with the palm of my hand.
I bought a pistol grip shift handle that was made for import, but had a buddy with a machine shop drill and tap it for my Hinson shifter. I couldn't be happier with it. It's getting powdercoated now.
Hurst does not, unfortunately! I'm probably going to give the ball to my friend
