Limited slip ??
Old Apr 12, 2019 | 01:45 PM
1997 C5's Avatar
1997 C5
Default Limited slip ??
I have 97 C5 Base A/T trans. I called dealer and dealer looked up my car by vin and says it is not listed whether mine has limited slip differential. How do I find out if mine has
limited slip differential or not?
Reason is i'm getting ready to replace the differential fluid out and I need to know whether I need to add limited slip additive. I ordered the oem differential fluid with additive add in the diff. fluid already I will see it tomorrow.
If i do use the gear oil with LS additive already in the diff. fluid, will this harm or damage the differential?
Old Apr 12, 2019 | 01:51 PM
Big_Mike_SD's Avatar
Big_Mike_SD
Veteran: Marine Corps
St. Jude Donor '21
You ordered the right fluid. (AC Delco 75w90 LS gear oil with friction modifier additive already included)
Last edited by Big_Mike_SD; Apr 12, 2019 at 02:01 PM. Reason: Oil brand correction
Old Apr 12, 2019 | 02:01 PM
ArtClassShank's Avatar
ArtClassShank
All C5's have a LSD.
Old Apr 12, 2019 | 03:18 PM
1997 C5's Avatar
1997 C5
Thank you for inputs................................
From research 2 qts is all I need right?
Old Apr 12, 2019 | 03:49 PM
gimp's Avatar
gimp
2Q is what my google-fu tells me.
Old Apr 12, 2019 | 04:55 PM
lunaticfringe007's Avatar
lunaticfringe007
Check the build codes on the decal in the glovebox. I should have a code for what diff you have.
To Limited slip ??
