Rich or lean?
Old Apr 23, 2019 | 12:55 PM
flyingmfrc's Avatar
flyingmfrc
2020 C5 of the Year Winner- Unmodified
Default Rich or lean?
OK C5 science guys.....Would a rich or lean condition cause popping or gurgling on deceleration? I suspect a rich condition. I'm at 7,000 feet which could trend to the rich side. Just trying to figure out whether a "Tune" could correct that condition or if I really need to change exhaust to get rid of the popping? Borla S Cat Back.
Old Apr 23, 2019 | 12:59 PM
Put an x-pipe on the car and I would bet the vast majority of the popping will disappear. It sure did on the ‘00 I had.
Old Apr 23, 2019 | 01:11 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
When I had changed out my OEM exhaust to Borla Stingers I had that "popping" I think you're talking about...installed an X pipe and that basically got rid of it !!
Old Apr 23, 2019 | 01:12 PM
C5 Diag's Avatar
C5 Diag
Old Apr 23, 2019 | 01:16 PM
STRMLNE's Avatar
STRMLNE
Just installed Corsa Sport. I now have popping on decel. It’s a little worse when cold. I actually don’t mind it too much. Sounds pretty good to me!
Old Apr 23, 2019 | 01:34 PM
SLOWRYDE's Avatar
SLOWRYDE
If it’s on the stock tune still it should be set rich. From what I’ve read GM sent them from the factory with a rich tune for safety reasons. This would cover the car being sent to all different altitude and temperature environments it would be sold and used in and avoid a potentially lean condition. I suspect yours is that way too.
Old Apr 23, 2019 | 01:36 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
I have an opinion, Since you are at 7000 feet and its not what anyone here has suggested.. PM me if you are interested in my opinion. if not its all good... no more train wrecks for me.. only facts since my opinion is 180 degrees from everyone else here.
Bill aka ET
Old Apr 23, 2019 | 02:05 PM
C5 Diag's Avatar
C5 Diag
Even at 7000 feet the PCM would decrease injector pulse width to keep the mixture at "stoic"....a tuner may be able to adjust the Decel Fuel Cut Off !!
Old Apr 23, 2019 | 02:33 PM
70RT440's Avatar
70RT440
Neither
Aftermarket high flow exhausts cause popping and gurgling because they allow unburned fuel in your exhaust to burn because they allow more oxygen to get pulled into your exhaust system. An X-pipe will reduce it.
Old Apr 23, 2019 | 02:45 PM
STRMLNE's Avatar
STRMLNE
Elevation shouldn’t matter. Pcm will adjust.
Old Apr 23, 2019 | 03:09 PM
flyingmfrc's Avatar
flyingmfrc
Thanks for all the replies, I really appreciate all the ideas. The odd thing is, I called Borla and asked about the X-Pipe and they said it would make it worse???? I may try doing a tune, but that's kinda expensive. The popping and gurgling isn't the end of the world, but I'd rather not have it.
Old Apr 23, 2019 | 03:29 PM
STRMLNE's Avatar
STRMLNE
Oh boy. If it doesn’t even out exhaust pulses, I wonder what Borla claims their x pipe does. Lol.
Old Apr 23, 2019 | 04:21 PM
flyingmfrc's Avatar
flyingmfrc
Old Apr 23, 2019 | 04:37 PM
SLOWRYDE's Avatar
SLOWRYDE
Bill aka ET
Why not share your opinion so we can all learn something? I learn quite a bit from your experiences. I’m sure others would too.
Old Apr 23, 2019 | 08:04 PM
KnightDriveTV's Avatar
0KnightDriveTV
Former Vendor
Are you positive the car doesn't have a tune on it?
Elevation changes will be compensated by the MAF+VE table and the short term/longterm fuel trims based upon O2 narrowband data on closed loop (car warmed and running normally), so decel richness would be avoided, especially given the fact the injectors shut off on decel. There is a DCFO (decel fuel cutoff) entry map that combines with the Baro tables to initiate entry into the DFCO...once the injectors are off, the popping would quit immediately (motor would just be cycling air vs pops=combustion)
Are you running a lower octane fuel by chance? Any codes? Could be possible your car, if truly stock, isn't going into DFCO, which could mean a variety of things visible in a scan. If you scan it actively, once you let off, injector pulse widths go off when DFCO comes on.
Old Apr 23, 2019 | 08:16 PM
captaineddie's Avatar
captaineddie
It sounds like your engine is running too rich due to you extremely high elevation. I would have thought your engine computer would automatically adjust the fuel flow to compensate for this, but if unburned fuel is entering your hot exhaust, maybe the heat inside the system is causing it to ignite and cause the popping (backfiring).
Old Apr 23, 2019 | 08:17 PM
wdcraig's Avatar
wdcraig
I almost always hear an off throttle burble ('01 manual, stock exhaust); which I assumed was completely normal. Normal or not, I like it. I'm at 760' above sea level.
To Rich or lean?
Old Apr 23, 2019 | 08:18 PM
flyingmfrc's Avatar
flyingmfrc
K.I.T.T.- My car is a 2000 FRC. It was completely stock under the hood, and everywhere else on the car, when I got it a year ago. So, I doubt there was ever a tune on the car. I run 91 octane Shell premium gas, no codes.... just popping and gurgling on deceleration. Only thing I have done under the hood is plugs, wires, and dual filter intake. What ever you just said in your post is Greek to me, but I'm assuming in laymans terms you are suggesting to get a tune???? Probably not something I can find on every street corner in Flagstaff...
Old Apr 23, 2019 | 08:25 PM
0KnightDriveTV
Former Vendor
Well, keep in mind, a "tune" is a simple as sending the PCM away for 150 bucks and getting it back...talking on your basic level tune here, nothing extensive. Does your 1-4 skip shift activate?
Old Apr 23, 2019 | 08:32 PM
flyingmfrc's Avatar
flyingmfrc
The 1-4 light on the dash lights up, yes.
