Window switch help
Old Apr 28, 2019 | 11:50 AM
garretthes's Avatar
garretthes
Default Window switch help
My 2000 does not have the memory option. All the options I see for replacing the window switch are crazy expensive. What are my options?
Old Apr 28, 2019 | 11:55 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
a used one from , http://www.vettenuts.net/
or take it apart and see if the contacts are dirty or worn, file and clean them ???
Old Apr 28, 2019 | 11:58 AM
garretthes's Avatar
garretthes
The drivers switch actually broke in half. The passenger swith fell into the door panel so it’s impossible to press the buttons.
Old Apr 28, 2019 | 01:58 PM
rrwirsi's Avatar
rrwirsi
Sorry to hear about your window switch issues. Just another GM lack of using quality parts. Until you resolve your issues, you may want to consider buying a Window Valet. Once program, you tap the open/close on your fob three times and they lower/rise. I use mine all the time in the summer.
C5 C6 1997-2013 Corvette Window Valet, Taillight Seals and Skip Shift Eliminator Bundle -SouthernCarParts.com
Old Apr 28, 2019 | 03:32 PM
fake's Avatar
fake
Find one at a corvette junk yard i did and no problem!
Old Apr 28, 2019 | 04:01 PM
garretthes's Avatar
garretthes
so now I need to buy a fob
Old Apr 28, 2019 | 04:03 PM
rrwirsi's Avatar
rrwirsi
The cars came with 2. Did you louse them?
Old Apr 28, 2019 | 04:35 PM
garretthes's Avatar
garretthes
Ha! I think I’m at least the 4th owner if this car. No fobs when I purchased it.
Old Apr 28, 2019 | 04:44 PM
rrwirsi's Avatar
rrwirsi
Sorry to lean that you purchase the car without the fobs. That sucks.
Old Apr 29, 2019 | 08:37 AM
FX VETTE's Avatar
FX VETTE
I’m fairly certain the memory option switches will still work for your non-memory option car. You should be able to get both switches for under $100 shipped off of fleabay. Just pull the door panels off, replace, and enjoy your vette.
Old Apr 29, 2019 | 10:31 AM
garretthes's Avatar
garretthes
Thanks, I will try that.
Old Apr 29, 2019 | 02:30 PM
You can get a good used one from one of the forum used parts vendors. Pulling the door panel is easy and so is replacing the damaged switch.
To Window switch help
