Need help finding #27 fuse.
Old Apr 30, 2019 | 12:28 PM
C908's Avatar
C908
Default Need help finding #27 fuse.
I opened up the fuse panel under the dash on the passenger side of my 99. I can't seem to find anything that indicates which fuse is the HVAC #27. Could someone please show me a picture of where its located ? I just need to pull it and see if it will do a reset. Thanks !
Old Apr 30, 2019 | 01:19 PM
JR-01's Avatar
JR-01
Do you have an owners manual? The diagram is in it.
Old Apr 30, 2019 | 01:23 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Old Apr 30, 2019 | 01:35 PM
C908's Avatar
C908
I found it, didn't realize the diagram was on the back side of the fuse box cover. Turned out pulling the fuse did not correct the problem. My center vent and drivers vent only blow cool if I set it on 60. Soon as I turn it to 61 the air doesn't blow quite as hard and starts blowing warm air. The passenger side seems to work OK. The dealer said the first thing they would do is run a dye test on it, I may have to go that route.
Old Apr 30, 2019 | 01:38 PM
C908's Avatar
C908
I did find my owners manual finally, it was in the house instead of the car where it should be. Thanks for your help, I appreciate it.
Old May 1, 2019 | 11:19 AM
Phanni's Avatar
Phanni
Running a "dye" test will show if there is a leak in the A/C system (freon).
I'm not real sure why there'd want to to that.
To Need help finding #27 fuse.
