Dash lights - Is this working right?
IIRC, on my '97 the illumination level on displays like the DIC, radio display and A/C temp display were brightest with the running lights/headlights OFF and dimmed when you turned those lights on.
On my '03 AE coupe the displays are dimmest when the running lights/headlights are OFF and brighten when I turn either ON.
This seems totally bass-ackwards.
They are so dim as to be unreadable with the transparent targa roof on a sunny day.
What's right?
What's right?
What's right?
What's right?
The Rabbi (05-31-2019)
That's my point. My AE is DIMMEST during the day and brighter at night. Exactly backwards from what you would expect!
RR, again, you're not getting the PROBLEM.
Night level is OK Doesn't matter and I know how to vary it if I care to.
=====>>DAYTIME LEVEL IS TOO DIM!!!!!<<=====
Can't see the DIC info on a sunny day without turning the running lights on.
Day mode should be brighter than night mode and it ISN'T!
Something's screwed up.
OK - I’m slow. There is a sensor on the dash near the center ‘grill’ that triggers the daytime dash light level. It evidently isn’t working. Unfortunately it maybe difficult to get to - I don’t know how it is held in place., but I would start there. Sorry about my confusion.
Received 1,679 Likes
Subscribed for solution
AE Guyand all others: The Solution!!
When the running lights/headlights are on (night mode) the brightness of the dash is controlled by the Instrument Panel Brightness Control on the left edge of the instrument cluster. This was working.
When the running lights/headlights are off (day mode) the brightness of the dashboard is controlled by the sensor just above the [FUEL] button on the DIC control panel.
The lights were terribly dim all the time.
BUT, if you clean off the schmutz that was all over the sensor & plugging its' vision....YAY everything works properly now!
I can keep and eye on things now during the day.
BTW, the sensor up in the defroster grill seems to be for the Twilight Sentinel® option that is present on my AE Coupe.
FX VETTE (05-31-2019)
Gracias Amigo, good to know
Carmine97 (06-01-2019)
