turn signal help needed
Turn signals not working - CorvetteForum - Chevrolet Corvette Forum Discussion
If it's only one side, then it's probably the multifunction switch (MFS).
If when the problem is present it affects both sides, then it's probably the Hazard Switch going bad. In a C5 the turn signal and hazard functions are provided by the hazard switch.
You can replace the hazard switch, but a Hyperflash Harness should fix your problem and is easier to install. As an added bonus, it will allow you to install LEDs in the future with no hyperflashing.
A hyperflash harness replaces the portion of the hazard switch that handles the turn signals with a flasher that's LED friendly. Hazards will still hyperflash because that function remains untouched in the OEM hazard switch.
Check this one out. It's completely plug-and-play: no splicing or anything.
