Gas mileage
OP
what at is your actual mileage? as calculated by dividing miles driven between fill ups and gallons pumped to bring back full,
the ars gas gauge has nothing to do with this, you may not even have a problem.....if you did it would probably exhibit in more ways than MPG like throwing codes and lack of power. Just a thought
02/14 130628 324.2 13.9 23.3
03/04 132578 306.1 13.0 23.5
04/06 133757 255 11.5 22.2
How about from my gas log for the 1st fill up of the month of this year? Stock with Corsa Exhaust , Auto '03 Coupe. Mostly ethanol regular and all around genital cruising.
Date Total mileage Miles at fillup, Gallons put in till full, Miles per gallon.
Be careful out there!
and there is very little to be gained.
Factory timing is already 40-45 heck I've seen 50* in some engines for cruise.
There is nothing left to 'tune'
Believe me when I say the factory has already done 99% of all the easiest most obvious stuff to bring that window sticker number down for the EPA and to compete with every other car who's had the same thing done.
Cold start only lasts a few minutes. Like 4-5 minutes.
If you drive for an hour, the first 5 minutes is negligible.
And if you 'tune it out' which basically just means removing that 20-30% extra fuel for the first 5 minutes (when the car should be sitting near idle anyways) It will drive like **** for that 5 minutes.
The fuel savings is negligible again because at idle speeds the engine is using the least amount of fuel possible.
So 30% extra to a "minimum quantity" is essentially nothing.
My previous house had a dirt driveway and just driving on that 300 yards before getting to the 55mph highway, was worth a MASSIVE amount of fuel economy average. I'd idle down that and the car basically got 0mpg for 45 seconds to a minute, twice a day. The difference between that and simply getting on the road and go, it clearly more than you give it credit for.
I also don't recall my car running terrible at cold startup. Actually, quite the opposite. Now, I didn't take all of the enrichment out, but I decreased it quite a bit.
For the most part, fuel economy boils down to simple math. The computer keeps the car at 14.7:1 afr (or attempts to). X amount of cubic inches of displacement, times X amount of RPMs, tells you the fuel consumption. The only variables to speak of are what gear you're in (controlling final drive ratio) that's the big one,engine load (thus changing dynamic airflow) and fuel enrichment done in the tune, that's the small one. Past that, everything else is lost in the noise.
That was in spite of sitting in stopped traffic for over 2 hours with the air on while accidents in a construction zone clogged up I71.
I echo the sentiment; If you're sensitive about the miles per gallon and the cost of premium gas, maybe you're better served by a different car.
Displacement is also a meaningless quantity when concerning fuel economy. You can get better economy with a 6L V8 than 2L 122 cubic inch 4-cylinder if the V8 is more comfortable cruising at speed and rotates slower.
Finally engines should not be used for short trips. Please see more:
https://www.corvetteforum.com/forums...post1599560628
- 85 would have been my highest speed (and when merging, I do explore the upper range of the tach...why not?). We hit several construction zones (two seasons in the Midwest, winter and construction as the saying goes). We stopped off in Indianapolis, so there was some in town driving there, and again in Columbus where we overnighted- my gas mileage on this leg of the trip was 30.5 miles to the gallon. My wife on board and the trunk loaded with 2 suitcases. The return trip, we stopped in Cleveland and Detroit and overnighted in Detroit. When I pulled off the highway in Detroit our average fuel economy was 30 miles to the gallon.
The return leg of the trip- we dropped the top from Detroit to Michigan City, Indiana (lunch break and some slots for the wife)- I saw the average gas mileage drop to 28.5 miles to the gallon when we pulled off the highway. I typically see a drop in mileage with the top down, so no surprise there and we had some bumper to bumper traffic to deal with as we hit the constructions zones.
Temperatures climbed into the 90s yesterday around noon, so we put the top back up. We spent over an hour in bumper to bumper traffic at the Indiana/Illinois border, such that it took us 2 1/2 hours to get home (where it should have taken us an hour and a half). Outside temperature was 95 degrees; stop/go crawl, the worst imaginable traffic. Nonetheless, our average gas mileage was 26.5 miles to the gallon.
Our car a stock, '01, manual with over 109,900 miles. As the saying goes, your mileage may vary.
