Gas mileage
Old Jun 20, 2019 | 11:10 PM
Bills01vett's Avatar
Bills01vett
Default Gas mileage
How much gas mileage are you guys getting under normal driving conditions? I’m not beating on my car at all and mileage isn’t that impressive as I’d heard vette’s were? Anything I should look for maintenance wise?
Old Jun 21, 2019 | 01:48 AM
02general's Avatar
02general
I own a 02 Z06 that I drive regularly, mostly interstate driving. I get around 22 to 23 miles a gallon running 80 mph. Car is all stock with only exception of cats being deleted.
Old Jun 21, 2019 | 04:08 AM
Kingtal0n's Avatar
Kingtal0n
I love optimizing for fuel economy. Being poor makes you an expert at squeezing every last penny of fuel out of the vehicle.
First thing and most importantly is how you are measuring economy.
You can NOT trust electronic measuring devices. They are for reference, and sometimes very accurate, however should not be relied upon.
The consistent method is as follows:
1. fill tank to top using specific pump
2. drive exact number of miles (must have accurate mileage recording)
3. re-fill to the exact same fuel height (using the same pump-shut off helps here) and divide fuel used over mileage (you know what I mean)
Next some basic rules.
1. Weight is the most important factor. A 3000lb vehicle with any size engine (2.0 or 6.0L) should be able to achieve 30mpg through a manual transmission with a non-parasitic rear (like a ford 9" or something) and proper gear ratios.
2. Automatic transmissions are not all equal. TH400 and 4l80e will use significantly more fuel than say, 700R4, due to the heavier rotating internals and friction. So depending on which auto you are using will affect fuel economy. For reference it seems like 4l80e will reduce mileage around 3 to 5mpg from the 4l60e size trans.
3. Cruise RPM vs engine size is secondary to weight. Large engines need to cruise at low RPM or they will consume excess fuel. Small engines (2L~) don't seem to mind as much.
And the rest of this should help put the nails in this...
Fuel economy posts of the past
https://zilvia.net/f/showpost.php?p=4957504&postcount=7
https://www.thirdgen.org/forums/tech...ml#post4840465
https://ls1tech.com/forums/generatio...l#post19737797
https://ls1tech.com/forums/general-l...l#post19198477
Old Jun 21, 2019 | 05:30 AM
Grandpa1's Avatar
Grandpa1
Well, I don't do all that.
I just fill up and write down my mileage and go. When I fill up again I hand figure my mileage.
I get around 22-24 mpg on at highway speeds with my 03 vert A4. Not much different in town just cruising around.
I'm happy with that considering it's a 350 hp sports car.
Old Jun 21, 2019 | 05:41 AM
awches's Avatar
awches
I used my '03 Coupe Auto trans with the stock rear for just cruising about the country side. Also keep a log on every fill up with mileage. For the 2 yrs and 3 months I've had this car it's always in the 22 to 26 miles per gallon range.
Old Jun 21, 2019 | 06:23 AM
ArtClassShank's Avatar
ArtClassShank
19mpg, my average speed is 30mph. I sit in traffic a lot.
Old Jun 21, 2019 | 07:54 AM
Denny Kohlman's Avatar
Denny Kohlman
I have a 2000 coupe A4 and on a level highway with no wind I am around 30mpg. My overall MPG on the gauge, which I never reset, is just a little over 25.
Old Jun 21, 2019 | 08:10 AM
walleyejack's Avatar
walleyejack
02 Z, right around 15mpg.. C6 and C7 s i have owned easily get 30+
Old Jun 21, 2019 | 08:21 AM
peteinpa's Avatar
peteinpa
I average 20-21 mpg in my 2000 vert. Mainly around town driving.
Old Jun 21, 2019 | 08:53 AM
RPGR90s's Avatar
RPGR90s
2000 Convertible. I average about 22mpg driving the backroads here in southern MI.
Drove into the big city (Detroit) last weekend for a graduation and was astonished to see the average on the DIC shoot up to 28mpg (80mph on the freeway, 6th gear, A/C on).
Probably the most overlooked feature of the car is its fuel economy. It gets better overall mileage than my 2014 Ford Escape EcoBoost. And that's got a 4 banger!
Had a high school buddy with a '70 RoadRunner (383) that had to get no better than 6mpg, which meant the car looked great sitting in the driveway. lol! I can't think of many older high performance cars that get in the 20's.
Old Jun 21, 2019 | 09:07 AM
Bills01vett
I’m only getting about 220 miles per tank according to my gauges and I reset them after every fill up. All city driving so fall. Haven’t had it on the highway at all yet.
Old Jun 21, 2019 | 09:34 AM
50thz06's Avatar
50thz06
03 Z - I get mid 20's in town. If I road trip I can easily get 28.
Old Jun 21, 2019 | 09:37 AM
USAZR1's Avatar
USAZR1
My 2002 C5Z with H/C/I/E (450whp/402wtq) and 3.90 gears gets around 21-25mpg on the highway @ 75mph.
Coolant temps in town traffic with a/c average 205deg and on the road, around 195deg.
Old Jun 21, 2019 | 10:16 AM
DDaaryl's Avatar
DDaaryl
On a 280 mile road trip yesterday with no interstate I got 31 mpg. It was all good until my gas gauge quit again and I think I may be out of luck with Techron recovery.
Old Jun 21, 2019 | 10:21 AM
Bills01vett
So how many miles per tank does that usually amount to? Do you think I need plugs, air filter? Does anyone use K&N filter in stock airbox?
Old Jun 21, 2019 | 12:45 PM
ibrockn's Avatar
ibrockn
Almost everytime I drive my car, I do 21 miles one-way on the freeway at 65-70 mph. With that, plus a little city driving, I calculate a bit over 24 mpg everytime I fill up.
Old Jun 21, 2019 | 05:41 PM
Forcedvert's Avatar
Forcedvert
You can’t run it empty, so how many gallons per 220 mi? That’s your true mileage. Mi/gal....
lots of people brag on this, some quoting the instant mileage, means nothing.....
To Gas mileage
Old Jun 21, 2019 | 05:55 PM
My Vette Life's Avatar
My Vette Life
15 mpg
Old Jun 21, 2019 | 09:52 PM
vetteLT193's Avatar
vetteLT193
Best MPGs I ever had were in a stock coupe 6 speed. Way different than an auto convertible with the performance axle (still get low 20s on the highway with the auto vert) .
Old Jun 21, 2019 | 11:46 PM
bikeriderga's Avatar
bikeriderga
That kills gas mileage in any vehicle. I have a 2014 Honda Accord and when I sit in Atlanta traffic, my mileage will go from a usual 30 combined MPG to about 20 MPG.
