Driver side window and door lock
Old Jul 1, 2019 | 08:30 PM
meat85's Avatar
meat85
Default Driver side window and door lock
On my 1998 driver side window and door lock won’t work but works for everything else what could it be
Old Jul 1, 2019 | 10:42 PM
TinkersVet's Avatar
TinkersVet
harness connector in the door panel may be loose or corroded
Old Jul 1, 2019 | 10:45 PM
meat85's Avatar
meat85
Do I take off door panel could it be a fuse
Old Jul 2, 2019 | 01:00 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
That or the relays in the control module inside the door need changing.
Old Jul 7, 2019 | 01:51 PM
meat85's Avatar
meat85
Default Now it’s working
Went to storage It’s been atleast a week I also installed a new window switch a week ago and now it’s working maybe it had to reset itself very weird
Old Jul 8, 2019 | 02:53 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Mine would work then not work (passenger side), that went on for months before it worked less and less so I replaced the controller, got it from VetteNuts.
Confession: I tried replacing the relays but not having a solder sucker I damaged the tracers so I had to replace the board.
To Driver side window and door lock
