Best Adhesive
Old Jul 14, 2019 | 01:07 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Default Best Adhesive
Just picked up some padded armrests which fit onto of the door armrests. Looking for something other than velcro to attach? Thinking 3M tape? Suggestions? Thanks
Old Jul 14, 2019 | 01:47 PM
coletrickle35's Avatar
coletrickle35
Veteran: Marine Corps
C5 of Year Finalist (stock) 2019
St. Jude Donor '19-'20
3M double-sided adhesive tape will do
Old Jul 14, 2019 | 02:36 PM
The Rabbi's Avatar
The Rabbi
2018 C5 of Year Finalist
St. Jude Donor '14,'18
Not so sure that 2 sided tape will hold up to the constant usage. I ran a trim shop once and we repaired arm rests often. The pad and the door panel where it goes get sprayed with 3m yellow glue. After spraying let stand of a little bit so the glue becomes tacky.
Old Jul 14, 2019 | 02:49 PM
rrwirsi's Avatar
rrwirsi
I also use LOCTITE Spray Adhesive High Performance for stuff that Velcro does not make sense. It is a middleweight Bonding agent.
Old Jul 14, 2019 | 07:40 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
Mine came with double sided tape already on it and they've held up great for quite a few years now. Even here in Arizona heat.
Old Jul 14, 2019 | 09:53 PM
redzg's Avatar
redzg
3M yes, foam core no. Go for the red backed permanent outdoor rated tape:
Old Jul 14, 2019 | 11:36 PM
The padded armrests I got from Vette Essentials had double sided tape on them. Adhered very well to the door panel.
Old Jul 15, 2019 | 07:02 AM
Spaggs's Avatar
Spaggs
That is something I've been looking for, for my wife's 07' Mustang GT. It is especially appreciated that this tip, not to say the others are not, is coming from a Pro.
Thanks.
Spaggs
To Best Adhesive
