[Z06] Engine Cleaning
Old Jul 22, 2019 | 05:55 PM
SAS22's Avatar
SAS22
Default Engine Cleaning
Any advice guys? Thank you appreciate your input
Old Jul 22, 2019 | 06:03 PM
STRMLNE's Avatar
STRMLNE
How bad is it? I have a very difficult time spraying down the engine with a hose or steamer so I do it by hand. But if you really need to use a hose, there are some YouTube videos on how to avoid the alternator etc.
Old Jul 22, 2019 | 06:12 PM
Jim_ZO6's Avatar
Jim_ZO6
2020 Corvette of the Year Finalist (stock)
C5 of Year Winner (stock) 2019
I put Saran wrap around the alternator, sprayed the engine with Simple Green, scrubbed a bit, and then hosed it off. It turned out pretty good.
Old Jul 22, 2019 | 06:23 PM
Grandpa1's Avatar
Grandpa1
You probably will get a lot of sprayers and non-sprayers answering this.
I am a non-sprayer because of personal experience with electronic problems after spraying long ago.
I just take my time and use elbow grease.
My 03 vert was easy and once it's clean it doesn't take much to keep it that way.
Good luck!
Old Jul 22, 2019 | 06:36 PM
Arvalo's Avatar
Arvalo
I put a plastic grocery back over the alternator, then use simple green and a hose. I like to use compressed air to get that water out of deep areas and out from the injectors and such. Then I close up the hood and let it run to burn any remaining water off 10-15 mins.
Old Jul 22, 2019 | 07:12 PM
STRMLNE's Avatar
STRMLNE
Same here. Plus, there are just so many people on his forum chasing weird electrical bugs, I just don’t want to soak the motor down.
Old Jul 22, 2019 | 07:15 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
Since I have a regular model I'll clean that bitch with a hose lol.
Old Jul 22, 2019 | 07:24 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
ever think what it looks like under the hood going down the road at 70 mph during a rain storm ????? have used a hose on mine for ever !!!!!! (no issues, engine hot)
Old Jul 22, 2019 | 09:09 PM
JR-01's Avatar
JR-01
A friend of mine took his Corvette to a car wash and pressure cleaned the engine. It would not start and had to be towed to a dealership where they charged him $350 to find out what got wet and dried it.
Old Jul 22, 2019 | 09:30 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The dealer didn’t fix anything.
Old Jul 22, 2019 | 09:31 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Take off the red fuel rail covers at a high pressure car wash... yes a coin operated high pressure car wash.
Leave the car running. Spray whatever engine degreaser you want and let it drool as long as it takes to get your quarters in the machine.
Blast the ************ with high pressure water, yes high pressure water anywhere you please as long as you please. Put high pressure soap, then high pressure rinse if you’d like. Doesn’t matter.
Put the red covers back on and drive home.
Not kidding. I’ve seen HUNDREDS of C5s and C6s blasted with high pressure steam before sale. Does zero harm.
If you're me with a fully polished engine, you don’t do any of that. Different plan.
Old Jul 22, 2019 | 09:42 PM
Edmund Iverson's Avatar
Edmund Iverson
This video was very helpful to me in my quest to detail engine bays, I hope you find it useful, too!
Old Jul 22, 2019 | 10:51 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
one draw back of hose or pressure is if you get near the front of the intake and put a lot of water and pressure there you can get water into the knock sensor cavities and eventually they can corrode and send codes ??? I do avoid those areas except on engines I have had apart to which I have sealed the caps for the sensors !!!!
Old Jul 22, 2019 | 10:57 PM
JR-01's Avatar
JR-01
Not sure what they did. He just told me what it all cost him.
Old Jul 22, 2019 | 11:11 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
Engine heat will evaporate any water pooled in short order. Corrosion/crust builds up over time under poor conditions daily driven, but in all my time I’ve never heard of a knock sensor stop working due to corrosion externally. Usually when a knock sensor fails (very rare) it’s the sensor itself internally, probably caused by a combination of heat and vibration.
Old Jul 22, 2019 | 11:19 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
happened on my 2000 GMC truck !!!!! bought used and drove it for some time, knock sensor cavity still had some water in it and sensors were very corroded, and have heard of it in other vehicles (Mich.)
Old Jul 22, 2019 | 11:42 PM
Forcedvert's Avatar
Forcedvert
I washed mine at a car wash, no problem at all, just use common sense and run car afterwards for a while to make sure it’s all dry.
To Engine Cleaning
Old Jul 23, 2019 | 12:50 AM
Spaggs's Avatar
Spaggs
I usually hit my engine with Dawn dishwashing soap, hot water and a dish rag for regular washings. For tougher grease, I like using Purple Power and a scrub brush.
Spaggs
Old Jul 23, 2019 | 12:56 AM
SAS22's Avatar
SAS22
https://www.youtube.com/watch?v=FFzbOJL7LJU
I think this dude really knows what he's doing. I'm curious as to where one might find that degreaser? Rapid Remover?
Old Jul 23, 2019 | 09:42 AM
jjc508520's Avatar
jjc508520
Simple Green and a trip to the self-serve car wash. I used Purple Power once and that left a residue on aluminum stuff like the catch can
