Neverseaze or not
Old Aug 1, 2019 | 04:41 PM
Daddy o's Avatar
Daddy o
Default Neverseaze or not
Neverseize on spark plug threads? Yes, no, or maybe. GM manual says nothing about anti seize compound on plugs.
Old Aug 1, 2019 | 06:14 PM
wydopnthrtl's Avatar
wydopnthrtl
No.
I make sure threads are clean and torque them w/cold engine.
Old Aug 1, 2019 | 06:15 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
1000 % yes !!!!!!!!!!!!!
Old Aug 1, 2019 | 06:18 PM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
Originally Posted by wydopnthrtl
No.
I disagree IF you are going to use the standard OEM plugs which are good for 100,000. The plugs have a tendency to weld themselves to the aluminum block. I would always use the grease.
Old Aug 1, 2019 | 06:36 PM
killian96ss's Avatar
killian96ss
Definitely with aluminum heads. Make sure you use the silver anti seize made for aluminium and not copper which will cause misfires.
Steve
Old Aug 1, 2019 | 06:39 PM
MAD Matt's Avatar
MAD Matt
Yes, always use the aluminum antiseize with aluminum heads. Snapping plug threads off in the head will ruin your day!
Old Aug 1, 2019 | 07:15 PM
tentuna's Avatar
tentuna
Anti-seize sparingly and torque to 11 Ft-Lbs, per manual
Old Aug 1, 2019 | 07:26 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I use copper (higher rated temp) on mine always. All my gear head buddies do too.
Old Aug 1, 2019 | 11:21 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
No luber here as well. Never had a plug stuck in an LS head.
Old Aug 1, 2019 | 11:38 PM
killian96ss
Bad idea. Copper anti seize is alot more conductive than silver anti seize which can cause misfires plus the copper flakes are harder than aluminum which can wear out the aluminium threads. The copper flakes also have a natural galvanic reaction with aluminum which is also bad. I've personally had misfire problems using it and have seen similar problems on other forums from people using it on spark plugs. Copper anti seize is great on header bolts or other high heat applications. There is alot of info on the out there on this if you want to research it.
Another point not mentioned enough about silver and copper anti seize is that it increases torque values by 20% so when you torque the spark plugs you should use 20% less torque to prevent breaking the plugs or stripping the soft threads in the heads. It's also worth mentioning that alot of modern spark plugs already have a nickel anti seize coating and some manufacturers recommend not using any sort of anti seize. I'm not sure if the Delco iridium plugs have this coating, but I always put a little on the threads anyway.
Steve
Old Aug 2, 2019 | 01:17 AM
Yes, use anti-seize on the threads.
Old Aug 2, 2019 | 08:00 AM
Daddy o's Avatar
Daddy o
So, what happens the next time you change plugs and you have dried and gunked up old compound in the head threads? Surely using a thread chaser to clean out the head would let debris into the cylinder. Not trying to over think a spark plug change but the yeah and neah seems to be devided. Since I'm changing them and the wires because not for high mileage ( car has 25,000) but since they are original and 15+ years old I feel it's a good deal over do. All my other (go fast) cars are steel heads. Only a good plug socket and ratchet is required on those. Car runs great for last 15 yrs. just some p.m. Is due now. Thanks for all the input.
Old Aug 2, 2019 | 09:52 AM
Pounder's Avatar
Pounder
1/4 mile/AutoX
you should live in Michigan and try to get the plugs out of a truck with 100k or so and don't even want to think about a plow truck without neverseize !!!!!!!!!!!!!!!!!
Old Aug 2, 2019 | 10:52 AM
runner140*'s Avatar
runner140*
Old Aug 2, 2019 | 04:26 PM
oharal's Avatar
oharal
Another vote for anti-seize. Anytime you thread steel against aluminum you should. Aluminum is smeary and will gall against steel and get stuck. I'm like the grandma in the Frank's RedHot commercial with never seize. I put that s--- on everything!
Old Aug 2, 2019 | 07:14 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
YES be sure to use anti-seize on the spark plug threads.
Old Aug 2, 2019 | 09:05 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
“Copper conducts” like aluminum doesn’t?
The heat in a head dictates higher heat material as exhaust temps reach past 1k degrees on a hot run. The silver anti seize is more apt to turn to dust.
Use whatever your book tells you, I’ll use copper like I have for Decades on my engines.
To Neverseaze or not
Old Aug 2, 2019 | 10:01 PM
Pounder's Avatar
Pounder
1/4 mile/AutoX
funny aren't the threads the ground so if it conducts better that wouldn't be a good thing ????
Old Aug 2, 2019 | 11:18 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
The heavily built V8s (many forced induction) I’ve seen I’m sure were all screwed because copper anti seize was used?
Umm, no. They’ve all been beasts.
Old Aug 2, 2019 | 11:55 PM
Mr. Black's Avatar
Mr. Black
lol so are the ones making 1500 hp with nothing on the threads.
