Exhaust Tips
Old Aug 2, 2019 | 02:52 PM
dleibman's Avatar
dleibman
Default Exhaust Tips
Looking to spice things up a bit. Would like to change out oem oval tips to round tips. Not looking to upgrade exhaust system, like the sound of my AE just the way it is. Do not mind if new ones are bolt or weld on. Would like a flared tip like the c7 or such. Any suggestions would be appreciated, also photos of what you guys have done. No idea of tip size needed at both ends. Does anything else need to be done if changing only the tips. Not a fan of the thin edge tips
Old Aug 2, 2019 | 04:28 PM
STRMLNE's Avatar
STRMLNE
Just do a google search. Lots of options.
https://pypesexhaust.com/i-12200766-...ps-evt157.html
i honestly don’t think many people on here change the tips. Most do a new axle back. Check out the corsa sport. Best of both worlds.
Old Aug 2, 2019 | 05:12 PM
Mr. Black's Avatar
Mr. Black
No Hostility Be Happy
I think you would be a perfect candidate for a used Ti stock Z exhaust system. They pop up often locally and in the classified here, and honestly it would be easier to swap out than monkeying with cutting off the tips and adding new ones.
To Exhaust Tips
