My windshield washer tank leaks however I cannot find where. I took it out and it looked fine. I took out the float and the pump and added silicone to make sure no fluid would escape and parked in the garage overnight. In the morning I checked the car, no fluid in tank and no fluid on the floor. Any ideas.
I had a similiar issue. I would fill my tank with fluid and after a few days would get the warning it was empty. I traced the problem to one of the outlet hoses that was funneled close to the left hood hinge. Apparently the hose over time was being pinched every time the hood was opened/closed and eventually created the hole. I fixed the hole and rerouted the hose and all is fine.
