Help to save and retrieve 1998 C5
Ive messaged Dave @DeeGee just a short while ago. Thanks for that pointer too.
@Robrote I’ll enjoy reading through that thread this evening.
@JR-01 There’s no point in my considering going to the effort of retrieving this car at all if I’m not going to approach it positively and hope for the best. You said it yourself, actual condition is an unknown quantity at the moment so what’s the point in downing it? It would be different if I was talking about buying it blind but if it can be resurrected at fair or reasonable cost, that’s all it’s going to cost me. If this works out I’d like to keep it but at the moment I think the car is worth a minimum of £10,000 GBP here in the UK if in good order ($12,000). I can therefore spend quite a bit without worrying. I can also get paintwork done at an amazing price through someone I know.
I’ll hopefully get a slightly better picture of condition in a few weeks when my father goes out to Spain.
Go for it silver50 have fun and keep us advised on how it is coming along.
@JR-01, I was referring to what the car is worth here. My exchange to dollars was just to give a reference point. Mind you, even on ebay.com even rough looking C5's with high mileages still seem to command a fairly high price. Being that a lot of these cars are circa 20 years old I'd say any for sale other than low low mileage mint cars could easily have been tidied with paintwork and will have had various other aspects attended to as well. I don't see any great divide as a far as restored/unrestored? Unless it's different in the US, value is surely just about general condition and mileage. The exception in a case like this would be an ability to show good regular maintenance records but on the other hand if a host of recent expenditure is evident old records wouldn't matter too much. JR, you might end up with the last laugh here (I genuinely mean that) but I'd like to think it might end up working out. I've put in a lot of effort already in relation to researching getting the car moved to the UK so if I want to move this forward I need to keep faith. Downing it is not helpful. If I do get this car home and it becomes evident it isn't worth saving I'll be cutting my losses sharpish. Equally if and when I get to Spain myself things look really bad I'll be seriously reconsidering. Again, hopefully not. There should be a fighting chance it shouldn't be too bad.
Here’s my own one
For those that are interested they’re Brabus split rims I refurbished
This C5 could be a lost cause or it could need only minor work to get back on the road. No telling until you did into it. If the column is locked maybe you can get some wheel dollies to stick under the front tires? That way you can load it up on a trailer or flat bed.Good luck with it and looking forward to seeing photos of it.
So how much money should he spend on this $4000 car?
My girlfriend's stepdad passed away, parked in the garage at least since 2006 is his 1992 Suzuki Intruder 800.
I checked fluids, hooked jumper cables on it with car not running (friend into motorcycles told me running engine would be too much) sprayed a little shot of staring fluid, fired up on 2nd try.
Gas and exhaust stunk, running kinda boggy (slow to rev up) most likely the old gas.
Put in a battery and took it for a spin, old 1992 tires are totally dry, downshifted and let out clutch too fast, back tire skidded some.
Parked it and it's leaking gas, thinking it's the carbs, gaskets probably dry rotted, or fuel line.
It got to running better after warming up.
It's free to me, but...
I'm scared of riding it and someone hit me, way too many bad driver's, in a car much much more safe.
I say try starting it up with good battery, pour in some fresh premium gas, hopefully it's near empty.
Mine sit for almost 5 years may 2013- September 2017, but was in garage in Phoenix Arizona area, I kept gas low, would pour fresh gallon in every few months or sometimes years and fire it up and let it idle.
Replaced lots of stuff when I put it back on road, battery, coolant tank (was leaking before parking it) new belts and pullies, idlers and tensioners, just got new tires a couple of months ago.
Flushed and replaced coolant, oil, transmission oil (manual trans)
Hope no mice chewed wires.
I once had a 1981 Z28 Camaro parked outside in the country, mice got in and ate interior and wires, wasps or hornets invaded it, and Black Angus cattle dented it up rubbing on it to scratch themselves, lol.
It went to a salvage yard.
My worst fear is inability to tackle initial difficulties in Spain. At some stage I hope to fly out for a few days and ideally might try to arrange the transport for the same time. Obviously try to inflate tyres and see if I can get the car rolling and hope the steering column isn't stuck too. A question.
I was going to look this up, but if anyone can tell me anything about towing hooks etc, please do.
Am I right I will really need a battery in Spain, mainly to stand a chance of unlocking the steering ? Are these cars usually alright on jumper leads if say my transportation guy was to power it UP from his truck? I would perhaps take a battery but doubt an airline will allow it! It might not be all that easy to lay my hands on a battery out there, not knowing where to go and with language difficulties. Is there anything special about the battery I should know about?
I've got this nagging feeling my uncle might have mentioned years ago the column being mysteriously locked but there's a very high chance this was with a low or bad battery. I will try to get my father to see if he can check if the steering is free or not when he goes out in a few weeks. I understand early recalls may have meant it might well be free.
It ,might be worth that, across the pond/
When I see the price of the likes of this in the US it doesn't look particularly cheap. I imagine to those stateside the USD price probably feels similar to how we would see the GBP price here.
https://www.ebay.com/itm/1999-Chevro...on=3000%7C2500
One for sale here in UK
https://www.ebay.co.uk/itm/Chevrolet...IAAOSwFpNdHfmU
They're relative value may then be roughly the same which is quite interesting but you guys will get a fright when I say the red one with 97,000 miles translates to $17,000! You may want to start importing them!
He has to figure out how much money to put into it and know when to call it quits. I hope he does do it. I am just pointing out the possible downside.
Its a big if at at the moment but if it were to work out, firstly it’s not getting done to profit but secondly and fore mostly, if it were to be fixed ok, would you like to explain why “later on” with fluid changes and use it would “start burning oil or not shifting right?”
Also, this “hard to sell sat in the weeds idle for ten years, hard car to sell” Do you think they would be the title for an ad? Of course not, it would be a car that has been gone through in good shape so would be attractive.
As I say, sorry, losing patience with the completely negative, unfounded input. Bizarre. You say you’d like it to work out well. Fair enough, but it truly doesn’t sound like it. Also, why should this necessarily be worlds apart from the chap on here who bought the yellow car which is essentially ok.
I say the above with trepidation because you might be the one with the last laugh but oh boy, if ever there was a doubter and downer of something.
Not informing a potential buyer about the cars history would be dishonest, bordering on fraud. I guess if that's how you operate then you deserve what happens. I am done here even though I am one of the only ones here giving you an honest opinion. You don't seem to want to know the truth.
Good bye.
I would not be dishonest if I retrieve and eventually may sell the car. It would be true and honest to say it belonged to my uncle who became ill and it sat unused for a long time. I am also aware I have posted information here can and will be seen by others. I staunchly defend the fact that current order and condition upon sale are what matters most on a 20 year old car.
I am not sure you saw my post above about the 1999 Mercedes, it had not been cared for well and needed a lot of tlc. I suspect I put in around 150 hours last winter. I am acutely aware of the kind of things that go bad. However, I am keeping an open mind and hoping for the best. My reason for coming on here is for support and information in preparation for the task ahead. My very first reply (being from you) saying every system will need refurbished and it might cost ten times what I expect was simply unfounded and unnecessarily discouraging.
I apologise to other forum members for this bickering but I did lose patience today with the other users input and remarks. However it was obviously the case other users similarly felt the input wasn't useful.
