Help to save and retrieve 1998 C5
My first task may be the hardest. The car is in a fairly remote location and as I mention unused for some time. I plan on getting it transported back to the UK, ideally as is, then work on it here, at home. My father will probably be the first to see the car in around three weeks time. He saw it not so long ago and it is all intact I believe. I may have a wait while estate/legal issues are settled before I can retrieve the car but hopefully it will happen relatively soon.
I would be immensely grateful to users here who may be able to provide me with support. I have started some reading and the column lock issue is a worry. It may be very difficult to get work done in Spain (I've no tools there, no close by garage services and language barriers) so I really want to simply get the car back here before tackling work. We have recently located keys for the car. I was hoping to get tires inflated and roll/steer the car ready for transportation but if the steering is locked, what a nightmare! If it has locked up, the column lock obviously needs power to unlock, so must I get a battery/12v to this dead car or is there any way I can get the car steering/rolling even if it meant cutting or damaging the steering column lock?
Unfortunately I don't feel I can ask my father to start trying to power up the car when he goes in three weeks time although until I read about the column issue I was going to ask him (and my cousins husband) to see if the steering wheel would release and see if the handbrake had been left on or not. That sort of thing.
Here's a picture I took in 2005. It looks much less like this now!
Popular Reply
Pleased to report things all went to plan out in Spain. Access for picking the car up wasn’t easy nor was exit by the tiny mountainous road for my transportation man. He had a lowish flat bed trailer being pulled by a pick up. Quite long so not the easiest to turn but we got there.
All tyres pumped up ok and some penetrating fluid on the rusted discs got the brakes moving ok. Handbrake indeed didn’t seem to be on (I was worried it may have been on at some stage even although the lever was down..). Came out of “Park” fine with no battery power and I suspect the steering column may have had the US recall meaning no locking of it.
Car was backed on by winch with no clearance issues from a strap around the rear subframe. The low trailer that itself tipped was perfect.
With the efforts required there I can’t say any extensive examination was done or was possible but I am pleased to say I didn’t spot anything untoward i.e. missing or damaged etc. It’s got a lot of debris here and there that has blown around from the wind I assume, exterior body is of course very mucky (wheels surprisingly clean!) and I was pleased coolant level fine (no chewed burst hoses obviously), oil level was fine too.
Interior really not too bad. I was amazed the leather wasn’t cracked or about to crack. It’s very dry of course though. Dash looks fine. Generally decent looking. Paintwork certainly poor with sun scorched peeling clear coat in various places/sections. Not saying it’s definitely ok but I didn’t spot any cracked rubbers/seals either. I didn’t see any sign of battery acid leaking at all so hopefully another plus.
I now await it’s delivery early next week so look forward to that. I’ll do a lot of vacuuming, washing and cleaning a bit at a time before doing much else. That’ll let me look closely at stuff bit by bit. I’ll then see about draining/flushing fuel and changing oil etc before considering trying a start up. I’m busy trying to finish some house renovation work so won’t be spending lots of time at it. May of course want to order and attain some parts of course too. Brakes for one thing.
Sorry no great pictures there wasn’t loads of time as we also had 5 other vehicles taken away from the villa the same morning to be scrapped. I enjoyed the nice Spanish weather but it was a whirlwind 36hrs there.
I know I’ll want to ask various things. Should I just post on the C5 tech help section for this?
Scott
I’d agree at 15+ years, and I don’t know for sure of course but it’d be a poor reflection on the vehicle if that were the case. I’d say it could be more surprising how alright most systems would be.
obviously, fuel will need replaced, oil, and tires.
But it might still be one worth saving if it was stored in a decent spot. and might not be that tough.
Sure to need a deal of recommissioning, I know but I do know it wasn’t laid up due to something like an engine or trans issue. Less and less visiting the property in Spain was the reason. Flat battery or not inconceivably a locked steering column were more likely the reason.
This is why the steering column being locked might be the first of my worries. You are right seized brakes are another which could be a more immediate issue.
Chewed wiring is possible and isn’t something that hadn’t crossed my mind. However I want to remain positive so must look on it positively woth best case scenario’s in mind rather than worst. There’s not a lot to be gained by second guessing everything. I don’t disagree re the fuel (perhaps particularly in heat) but a lot of people would say it can stay surprisingly stable for up to around the ten year mark. It’s not ideal I know, but me fitting a brand new battery and going for a start up might be a good way to get brakes freed and have the car mobile for transportation.
Are there any mechanical/quick/emergency releases of the column if absolutely necessary, even if not ideal ones?
Let use know the progress. I'm sure a few of us would-be willing to help you in any way we can.
BTW, We once ad a brit (I believe a pilot) here on the forum. He is now back in the UK, however I don't know if he still has his car. He is/was a great guy.
Understand though you just want to get it onto a trailer and out of there. Depending on what sort of surface it's on, you could consider 'movers' which are little platforms with castors to put under the front wheels. A rather less environmentally friendly solution is to pour copious amounts of diesel in front of the tires (tyres to you!). Diesel makes the rubber slippery as heck, so it can be dragged by cable against the locked wheels.
For sure it'll be expensive to fix, but ignore those saying it's worth almost nothing. They're referring to what's worth in (say) Detroit, which is about as much as a steak dinner. In UK it's worth a little more for being unique, but not a huge amount. Don't forget, if you are going to get it road legal then you'll need to improve it to at least MOT standard which might be a challenge. You'll want amber turn lights, beam diverters and so on.
Good luck though, subscribed to see progress!
@JR-01 There is not present reporting here rendering this an uneconomical to repair parts car. It was in decent order so seems highly unlikely to cost tens of thousands to fix. I have no idea why you are putting it down the way you have.
There might be surprisingly little needing done. I am most familiar with 90's Mercedes, a Mercedes Club member so am familiar with the type/era of technology. There is no reason to think a 70,000 mile 1998 corvette couldn't be resurrected with relative ease.
@andy dove I put the car through quite a strict SVA (single vehicle approval) test in 2005. I got euro rear lamps and other stuff from the US to do the work. There's actually been a C5 in and out of a garage in Edinburgh local to me. Not sure where they came from but they said they had got parts for it alright. Germany has quite a lot of American cars, it could be a place to source items from too. Unfortunately the car is on rough ground. Not ideal, and I think it could do with being turned round.
Good luck, you will love it. The fact you know the provenance of the car is a huge plus, so I think you'll be just fine. As just two examples (I have many more), I bought a 1990 ZR-1 that sat for almost 15 years, and turned it into a very reliable daily driver. Really wish I still owned it.http://www.zr1.net/forum/showthread.php?t=21794
And my current C5 sat for 10 years in the weeds before I got it, and now it's also my daily driver.
Here she sits just now. Small pic. Maybe just as well!
Next- Fill with fresh fuel and oil. With the fuel pump relay removed, crank the engine to get oil pressure. Put the fuel pump relay back in and fire it up. Then you can see what you have. It's a Saturday project that will cost you about 150 USD.
