Ceramic Pads...
Good luck
Part numbers.
F: CT1185-S 1521
R: CT1185R-S 1521
http://ampdautosport.com/brake-pads/corvette/
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
80,000 miles on these rotors in this photo, rotors and wheels are 17 years old.
the reason ceramic pads have less dust is because they are much harder. they require the pads to do much more work.. increase rotor temperature and make the rotors " Work Hard" … One of the best brake pad compounds uses is the soft pad compound found in BMW brake pads.. they dust more then any other pad out there. Ive always used carbon ferrous pards… they are soft, they dust, and they stop. the dust insures that the pads won't fade.. the dust insures the brakes will do what they are suppose to do.. Ceramic pads just like the ceramic bricks found on the space shuttle are designed to handel the heat of re-entry .. they are hard for a purpose. Its not for its stopping ability.. ) soft pads have a high coefficient of friction. reduce brake fade, heat distortion, and rotor discoloration. Problem is Ceramic is a buzz word and a marketing strategy.. the amount of ceramic can vary from a very little the a lot.. the more ceramic the less they dust and the more work it puts on the rotors.
Ceramic pads have their place on the track where stopping is essential and the pads can handle the 1500 F degrees of track events. track brakes do not belong on a street car. The softer the better,
Bill
80,000 miles on these rotors. no heat discoloration or warp
Many people have seen my rotors with 80,000 miles.. no dark heat distortion or warp, they are polished like a mirror because the pads I use are soift.. Ac Delco Carbon Ferrous. Al that squeal and squeak, and nails on the chalk board are due to the heat created by ceramic pads.. this heat tempers the rots and make them hard, thus creating an hard metal to hard pad scenario and will make more noise than I would even want. It embarrassing to hear that and it make your car appear to be a cheap, and a poorly maintained car.
I spent 3 minutes to clean my wheels before I puit my car away.
