Help needed: plastic trim push rivets
Old Sep 20, 2019 | 10:38 PM
95wht6spd's Avatar
95wht6spd
Default Help needed: plastic trim push rivets
Anyone know the size of plastic push rivets (xmas trees) needed for an A-pillar boost gauge trim piece? They are very small and can't seem to find anything this size at Lowes etc.
Old Sep 21, 2019 | 10:37 AM
bc6152's Avatar
bc6152
Did you try Ebay? I've purchased numerous sizes of fasteners that were OEM for my cars. I would ask for GM trim clips...
Old Sep 21, 2019 | 10:46 AM
jackthelad's Avatar
jackthelad
Try clipsandfasteners.com. Since it's not an OEM part you will have to search by type and size.
Old Sep 21, 2019 | 03:54 PM
95wht6spd's Avatar
95wht6spd
These are not OEM, that is one of the issues, this is for an aftermarket part. I don't know the size, that is the issue. Also searching for these is difficult, because there are a number of names for the product, and some listed in metric sizes, some standard. I was hoping someone had some experience with these, and knew the exact size.
I had taken measurements of the beat up ones, years ago, but I have moved, and not sure where the info is now. Even then, when I knew the measurements, I could not find a match, eBay, Amazon, WWW, etc.
Old Sep 21, 2019 | 07:51 PM
jackthelad's Avatar
jackthelad
You can do one of two things - talk to the aftermarket part supplier, or measure up the holes, etc., and either get push pins or self tappers that suit that hole size.
Old Sep 21, 2019 | 08:25 PM
51Hank's Avatar
51Hank
Try this outfit - they have many different options and brands. You migght have t o do some measuring and searching to find just the right one but they have a great selection - https://www.clipsandfasteners.com/au...show=45&page=2
Old Sep 21, 2019 | 11:46 PM
chasboy's Avatar
chasboy
Oldtimer
A parts place with a good selection should work
Old Oct 11, 2019 | 12:29 PM
95wht6spd's Avatar
95wht6spd
After more research I found these. Did a more general search, and the only place I could find these tiny fasteners was from Auto Meter (various places sell these).
3281 Pod/pillar fastener. Unfortunately they don't list the exact dimensions for a cross. I was hoping to pick up locally, but I guess I will just order a pack.
Old Oct 11, 2019 | 12:59 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
I've gotten pretty lucky at ACE Hardware a few times. They have a little section with automotive fasteners in the hardware department.
To Help needed: plastic trim push rivets
