storage
Old Oct 29, 2019 | 01:48 PM
namvet6869's Avatar
namvet6869
Default storage
Do any of you put your car on jack stands during winter storage????
Old Oct 29, 2019 | 02:15 PM
Fcar 98's Avatar
Fcar 98
I do not. I do add 5 extra pounds of air. I run Michelin run-flats and never had a problem.
Old Oct 29, 2019 | 07:12 PM
I’m Z one's Avatar
I’m Z one
2022 Corvette of the Year Finalist -- Modified
2021 C5 of the Year Winner - Modified
I store mine on my quick Jack and I put jackstands under the control arms so the suspension doesn’t hang
Old Oct 29, 2019 | 07:35 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Nope...sit on the tires all winter...if I do get any flat spotting, which is rare, it smooths itself out on the first long drive where tires get up to OT.
Old Oct 29, 2019 | 08:42 PM
Nope. All I do is add a few PSI to the tires and put some carpet squares under the tires to keep them off the cold concrete.
Old Oct 29, 2019 | 10:15 PM
Zjoe6's Avatar
Zjoe6
Nope. Extra 5psi and never a flat spot.
Old Oct 30, 2019 | 12:08 AM
CalF's Avatar
CalF
Do not put on jack stands.I put old plush carpet squares under the tires.A heavy plastic sheet under car for a barrier from cold concrete floor. Ctek tender and Bounce dryer sheets in passenger compartment and trunk. I also throw some mothballs in a tupperwear bowl and set under the hood. Cover and wait for spring. In an emergency i can get the car out of the garage in less than 2 minutes.
Old Oct 30, 2019 | 12:29 AM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
No jack stands, it sits on the floor....The only alternative I personally would use is the rolling tire cradles but, that's if it's not going to be driven for a very long time.
Old Oct 30, 2019 | 03:09 AM
Jistari's Avatar
Jistari
Nope. modern tires rarely flat spot and the shocks dont care and the springs would take a very long time to notice the difference between ride height and eight inches less than ride height.
Old Oct 30, 2019 | 03:31 PM
rws.1's Avatar
rws.1
No. I just pump up the tires to the sidewall max and park the car on a plastic tarp to keep moisture from the concrete floor away from the frame.
Old Oct 31, 2019 | 05:12 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
I leave mine on Race Ramps Flatstoppers.
Old Oct 31, 2019 | 05:22 AM
PaulGS's Avatar
PaulGS
Here in NJ, I just park it in the garage, pull the cover over it, and that's it. Whenever the weather is clear enough I take it out for a few hours. It doesn't sit too long. It makes me too happy to drive to let it sit all winter.
Old Oct 31, 2019 | 09:48 AM
Ramets's Avatar
Ramets
I'm so happy living here in SC to be able to drive all year round!!
Old Nov 1, 2019 | 01:33 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Do any of your guys drive your vette during the winter on days when there is no snow and streets are clean or do you just put them up and wait til spring?
Old Nov 1, 2019 | 06:06 AM
wscott62893's Avatar
wscott62893
I know plenty of guys do. Personally, I don’t because after the first snow there is usually a significant amount of salt on the roads which is very aggressive on metal components and expedites the rusting/oxidation process. I’m located in south central PA. Once salt is down, mine is locked up until after the first good rain in the Spring.
I put my car on jack stands and store my wheels/tires in my basement as I am running R compound tires. Tire manufacturers recommend to not store them in below freezing temps. Beyond that, hook up my trickle charger and that’s it. I’m out in my garage almost every weekend tinkering so I don’t cover mine. It takes 15 minutes to remount the wheels and go in the Spring.
Old Nov 1, 2019 | 06:24 AM
PaulGS's Avatar
PaulGS
I'll drive it whenever it's nice enough out, roads clear of salt and temps around 50 or more. It's not that often, but a couple times most months of winter.
Old Nov 1, 2019 | 07:49 AM
sofast's Avatar
sofast
2022 C8 of the Year Finalist - Unmodified
I do the same thing for the same reasons here in new england.
Old Nov 1, 2019 | 10:46 AM
Fcar 98's Avatar
Fcar 98
I do, But the roads must be clean and dry. I have driven it with the temps. in the teens. runs like it has 50 more HP.
Old Nov 2, 2019 | 04:48 PM
C5R USA's Avatar
C5R USA
Absolutely, I'll drive it with the conditions you already mentioned. I'm not home often at all but, if the streets are dry, the sun is out, and the temp is at least in the high 40's, I'll give it some exercise. We get rough Winters here in STL, and I remember a few that is was at least 3-4 months before I had the opportunity to drive it. I'm not the type that puts it away in late October, and then waits till April to bring it out again. I just happened to get home this Thursday, and yesterday the temp got up into the upper 50's, and guess what? I drove the Vette yesterday. It's actually very nice to drive during temps like that, you don't have to use the HVAC system.
To storage
