LED Bulb Conversion Issues
Old Nov 9, 2019 | 06:56 PM
Corvette505's Avatar
Corvette505
Default LED Bulb Conversion Issues
So today I converted all my exterior bulbs to LED (previously did the headlight low beams but not high beams and still have to do fog lamps). This including both front corner bulbs on each side, rear side markers, license plate lights, reverse lights, and taillights. Everything works fine except when I try to use the turn signals. Now they blink faster but that's only when I'm using the DRLs during day time driving. When I turn on my headlights as if I were driving at night the turn signal doesnt work and the arrow I'm using just stays lit with no flashing (with a buzzing noise coming from the relay). I did install a hazard relay as in the past my signals had a hard time working in general but the relay helped 100% with that till now. It makes a weird buzzing noise any time I try to use my turn signal with the headlights up. I dont know what to do or how to fix this issue. Any help is greatly appriciated, Thank You!
Old Nov 9, 2019 | 07:07 PM
Chillo32's Avatar
Chillo32
LED headlight bulbs and LED DRL cause electrical problem with these cars. Do a google search. You’re going to need a hyper flash harness and probably some resistors for your headlights. But even then things may not work properly.
Old Nov 9, 2019 | 07:24 PM
Corvette505
The headlights work perfectly fine absolutely no issues there it's the turn signals I'm having issues with, the flashing for indicating a turn.
Old Nov 9, 2019 | 07:27 PM
Pb82 Ronin's Avatar
Pb82 Ronin
The turn signals require resistors to eliminate the turn signal hyperflash problem. Call whomever you ordered them from.
Old Nov 9, 2019 | 07:41 PM
Chillo32's Avatar
Chillo32
Like I said. Need a hyperflash harness. Do a search. There a hundreds of threads on this issue.
Old Nov 9, 2019 | 10:21 PM
I agree - a hyperflash harness should solve your issues.
Old Nov 9, 2019 | 10:51 PM
01pewtervert's Avatar
01pewtervert
Default Hyperflash harness
Link to Hyperflash harness Link to Hyperflash harness
Old Nov 9, 2019 | 11:23 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Old Nov 9, 2019 | 11:45 PM
Chillo32's Avatar
Chillo32
Actually you can buy led bulbs with the resistors so that isn’t wrong. Most do the hyperflash harness though.
Old Nov 10, 2019 | 12:12 AM
Pb82 Ronin's Avatar
Pb82 Ronin
Originally Posted by jdmvette
How am I wrong? And why just quote me when EVERYONE else in the thread is saying the same thing? Way to be a douche.
Old Nov 10, 2019 | 05:23 AM
S.D. Perry Sr's Avatar
S.D. Perry Sr
I have no issues with my LEC conversion. I have change my headlights, DRL, Tail lights and the front marker lights (signals) and interior lights. The headlights (ACA style) run directly to the battery with the supplied harness and relays. This was a manufacturer recommendation to prevent problems. The corner lights which are switch backs, resistors where placed on them to prevent any hyper-flash. I also installed an hyper-flash harness, when I did the taillight conversion which are halo-leds. Over-kill maybe but as stated all my lights work without issue. As many have said the first thing I would do is a hyper flash harness which is very simple to do. If you have problems after that then try the resistors on the corner lights.
Old Nov 10, 2019 | 06:53 AM
jdmvette's Avatar
jdmvette
Night Owl for life
Because you don't need resistors you need a flasher bypass harness like EVERYONE else in the thread has said, friendo.
Old Nov 10, 2019 | 07:40 AM
cloud 9's Avatar
cloud 9
I put a hyperflash harness in my 97 and still had to put resistors on my brake lights or the traction control service light would come on. I haven't done any other led conversions yet. Hope all goes well.
Old Nov 10, 2019 | 09:49 AM
Pb82 Ronin's Avatar
Pb82 Ronin
And what exactly do you think the harness is? They use a relay instead of only a "resistor." A relay IS a resistor, as well as a snubber and a diode. I can't believe I'm actually having to explain basic auto electronics. But hey, if you all think I'm wrong...cool. OP make sure you DON'T use a relay or a resistor and let these guys know if it fixes your problem.
http://www.sourceresearch.com/newsle...orks.cfm?emART
Old Nov 10, 2019 | 12:27 PM
Frank Tringale's Avatar
Frank Tringale
When I bought my 2002 C5 a few months ago it had the rapid flashing turn signals due to the LED light change. I looked on Youtube and saw several videos on the hyperflash. I installed it and the turn signals work as they should.
To LED Bulb Conversion Issues
