Convertible antenna replacement
Old Nov 15, 2019 | 08:49 AM
SoAlVette's Avatar
SoAlVette
Default Convertible antenna replacement
On my 2000 convertible, my automatic antenna quit working and I want to replace it. The Stubby's will not fit. I have some ideas in my head of options, but I do not know what the
size threads are on the male base. Anyone have any idea?
I do not want to replace the automatic with another automatic or repair the one I have. I would prefer a Stubby style.
Old Nov 15, 2019 | 08:52 AM
Clancy209's Avatar
Clancy209
you may may not agree with me but, IMO I like it better down, reception is still good
Old Nov 15, 2019 | 09:25 AM
JR-01's Avatar
JR-01
Mine quit working. The teeth on the ribbon were worn. I easily replaced it for 15 bucks following this procedure:
https://www.corvetteforum.com/forums...-for-13-a.html
Old Nov 15, 2019 | 11:24 AM
MetalMan2's Avatar
MetalMan2
My 2001 Z06 has the automatic antenna, and pretty much the whole mast was missing when I bought the car. So a little while into my ownership I replaced the mast and it's been great ever since.
That said, after replacing the mast I came across a neat conversion product that I wish I saw beforehand:
https://www.amazon.com/gp/product/B07BCJ8RVY/ref=ox_sc_saved_title_9?smid=A30A036E461J8Q&psc=1 https://www.amazon.com/gp/product/B07BCJ8RVY/ref=ox_sc_saved_title_9?smid=A30A036E461J8Q&psc=1
Old Nov 18, 2019 | 07:04 AM
sirdano's Avatar
sirdano
https://www.amazon.com/gp/product/B0...6E461J8Q&psc=1
I swapped my power antenna with this. My only complaint is the antenna is too short and does not pick up anything. Put a 18 flex and it work 100% better. I went through 4 power antenna before I got tire of change them out
Old Nov 18, 2019 | 12:13 PM
Zeek's Avatar
Zeek
St. Jude Donor '07, '11 thru '24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
I got rid of mine completely.
Old Nov 18, 2019 | 04:14 PM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Why didn't you just leave the hole and drill a matching one in the other side?
Old Nov 18, 2019 | 07:50 PM
Zeek's Avatar
Zeek
Old Nov 18, 2019 | 08:32 PM
K-Spaz's Avatar
K-Spaz
Don't be coy, you did think of it.
Old Nov 18, 2019 | 08:33 PM
K-Spaz's Avatar
K-Spaz
Does look better without it, and fact is, I listen to USB, couldn't care less about the radio.
On my Vert, I replaced the original antenna with a factory stock replacement telescoping version. Hated that fn noise every time it went up and down when I started or shut off the car.
Old Nov 19, 2019 | 12:39 AM
My Vette Life's Avatar
My Vette Life
Anyone know of a delete cover to place or fill the hole?
Old Nov 19, 2019 | 06:57 AM
K-Spaz's Avatar
K-Spaz
just put the antenna down and disconnect the power to it. The shape of The Grommet that you need is such that you're best off just leaving it there. Even if you remove the antenna and then put a dummy plug in where that was, you still need that shaped piece to match up with the Contour of the fender. I did that for a while while I was trying to find a replacement antenna.
To Convertible antenna replacement
