The people who think installing a vararam is hard are the same ones who drill holes in their car to avoid removing their intake when they do the oil pressure sender.
Its not hard, and it’s a good product. As long as you get everything lined up with no leaks it probably won’t throw any codes, but a tune is always the best option.
Just some simple research reveals vararam yields the highest hp increase. The people that recommend the ziptie mod typically don’t want to pay for an intake and just lie to themselves.
Yea, I think I’ll keep it on order... all the post I see that are throwing “codes” are old post from 5+ years ago and any newer post aren’t having any issues. I’ll end up going with this intake, long tube headers, x pipe and exhaust Then retune this year in stage one... have a couple years performance wise this way then go supercharger eventually.
so don’t fasten then ducts is basically the “secret” from what I see.
Im mechanically inclined so I’m sure I’ll be fine installing this thing....
Correct, dont bolt on the air ducts to the fog light areas. It will stay by itself and align by design. I had some struggles and then when I looked, I said it is the air dam bolts. Took em out and fit way better.
The one way to get true cool air in is to remove the plastic housing by the fog lights and install screens. C5 does not have a grill air intake is from bottom up
Not true. I nstalled a vararam just a few months ago and I am getting p0171 and p0174 on my 04 C5. The only way for me to get this to disappear is to get it tuned. I installed the vararam and power duct. When installed it per the instructions the codes almost immediately came up. I had to move the maf to the stock location, then the codes did not come up for a few days. I then used a DiabloSport Trinity to change the tune and lean out the fuel injector curve. No codes but the car was not running right. I didn't feel this was actually the right way to do it so I returned the tune to stock.
Just installed a vararam on my 2000. It was a PIA. It took many hours, cuss words to the engineers and it still does not fit right. Right side fit pretty good but left side still does not fit right. Left fog light does not lign up with the hole, Finally just gave up on it. Thinking about installing the stock setup and burning the vararam
Yep... horrible fit because of bad engineering. I used the stock plastic duct around the fog light because it used the fastening point at the park light. I cut an opening in them to match the vararam. The vararam needed a fastening point at that location because when installed it would drop down and cover the fog light. The tunnels that run up to the air filter needed to be installed loose. I then used an aluminum "L" shape bracket and attached it to the top of the tunnel so that it basically hooks at the top of the stock plastic fog light duct. Complete PIA to install. The tunnels need to be designed with some flex in them.
reading all the reviews on "how hard" it is to install the Vararam mentally prepared me to make the job harder than it was.
Grab 3 beers, a few wrenches and take your time....it wasn't bad at all
I actually let mine sit on the shelf for 5 months because I was dreading the so called pita install .....wish I would of just installed it when UPS dropped it off
Here is a link to the installation video that will help tremendously!
