Bought a vararam. Having second thoughts
Old Dec 5, 2019 | 08:25 AM
brooksy088's Avatar
brooksy088
Default Bought a vararam. Having second thoughts
Hey guys, I'm in Canada but I ordered a vararam b2 and air bridge from summit. Hasn't been shipped yet... but now I'm looking at all the issues... thinking I should switch to the blackwing just for simplicity... Are the vararam still throwing that many codes ? My car is a stock 2000 FRC.. ordered intake , will order long tube headers X pipe and exhaust in spring put it all on at once and retune..
Hate to sound like one of those guys. But I am haha.
Old Dec 5, 2019 | 09:21 AM
pjdbm's Avatar
pjdbm
I have it on my car two years now, never an issue. Very few people that I read had issues.
Old Dec 5, 2019 | 09:42 AM
Gordy M's Avatar
Gordy M
Most of the issues occur with the early versions (circa 2000), current versions are just follow the directions and little to no problems. After adding the LT headers and driving about 100 miles it would be good to get a competent scan/log and retune the PCM. Just adding the true cold air (drawing outside ambient air vs engine bay air) will lean out the engine slightly but most C5 were tuned slightly rich anyway.
Old Dec 5, 2019 | 10:19 AM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
I bought a Vararam about 5 years ago and the fit was HORRIBLE !!...sent it back and got a Blackwing !!...excellent fit and no “lean” codes !!...the PCM will adjust !!
Old Dec 5, 2019 | 10:57 AM
ArmchairArchitect's Avatar
ArmchairArchitect
Banned Scam/Spammer
From: Philadelphia PA (Birthplace of the USA, UNESCO World Heritage City)
Just do the zip-tie mod and add a hood seal with $8 of marine weatherstrip from Lowes/Home Depot. Save yourself hundreds.
Old Dec 5, 2019 | 11:10 AM
z06801's Avatar
z06801
I actually have a C5z airbox with this done, hit me up if you want it
Old Dec 5, 2019 | 11:15 AM
ztheusa's Avatar
ztheusa
Veteran: National Guard
All ANY of the so-called "cold" air intakes do anything but lighten your wallet.
Old Dec 5, 2019 | 12:34 PM
RSbeast's Avatar
RSbeast
Keep the vararam. They work.
Have had both an original and a b2 on my car for the past 7 years. The only complaint is stellar track times for the mods.
Old Dec 5, 2019 | 01:11 PM
Jim_ZO6's Avatar
Jim_ZO6
2020 Corvette of the Year Finalist (stock)
C5 of Year Winner (stock) 2019
I have a Blackwing, and never had an issue.
Old Dec 5, 2019 | 04:36 PM
Chris Draper's Avatar
Chris Draper
From: Gilbert, Arizona Currently Own: 1998 Coupe YouTube: My Corvette Life
Mine fits and works fine. Never had an issue before or after it was tuned.
Old Dec 5, 2019 | 11:04 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
I have an 04 and the Vararam is giving me lean codes for bank 1 and 2. If you getting it tuned it won't matter anyway. Have not really ran it too hard so since it's running too rich. So I'm actually not sure how much better the vararam is. Now that the weather is getting worse I don't drive it much. I probably won't tune it until I put on a set of headers.. I had Z06 fog light vents installed before I installed the Vararam and noticed the the sir intake temps were at ambient as long as the car was moving.
Old Dec 5, 2019 | 11:54 PM
I ran a Blackwing on the last two C5s I owned. Both were a perfect fit and no codes thrown at all.
The Blackwing is not a true cold air intake like the Vararam, but it does work well.
Old Dec 6, 2019 | 10:08 AM
namvet6869's Avatar
namvet6869
Just installed a vararam on my 2000. It was a PIA. It took many hours, cuss words to the engineers and it still does not fit right. Right side fit pretty good but left side still does not fit right. Left fog light does not lign up with the hole, Finally just gave up on it. Thinking about installing the stock setup and burning the vararam
Old Dec 6, 2019 | 10:25 AM
Clancy209's Avatar
Clancy209
Black wing, varam, air raid, all mount in the same position, with modified air bridge, they are all the same no better
Old Dec 6, 2019 | 12:22 PM
waupachino's Avatar
waupachino
The Vararam draws outside air only from in front of the bumper, I've had mine on the car for over 10 years with no issues ever. Stand in front of the Car and you can actually hear the Air sucking into it.
Old Dec 6, 2019 | 02:02 PM
Gordy M's Avatar
Gordy M
For the boulevard cruiser, you will not notice any appreciable difference between a true cold air intake system and a closed hood air filter. However if you do track, time trials, autocross, drag race, etc. there is a difference. Lap times and time slips will show the real results. If I were just a cruiser, I would save my money and enjoy the Corvette the way it came, being I exercise my Corvette to extremes I want the best possible performance for the class I run in.
One of the biggest problems with aftermarket air cleaners is going to a smooth coupler. After many discussions with a few software engineers (who developed the C5 PCM software) I found out only 96kb of the PCM could be altered by tuning and the remaining was unalterable--including the accordion style coupler. I was informed the air going into a cylinder was not smooth but pulsated by the opening and closing of the valves and to maximize the limited ability of the 16 bit computer running the engine management, it was looking for the turbulence of the coupler and making changes to the engine management system based on that turbulence.
Old Dec 6, 2019 | 09:56 PM
walleyejack's Avatar
walleyejack
go Vararam or go home. they work. little extra effort to install but no big deal. true cai
To Bought a vararam. Having second thoughts
Old Dec 6, 2019 | 10:31 PM
Not4spd's Avatar
Not4spd
I installed mine, it really wasn't that bad, just a little tedious, but does not take a rocket scientist to figure out. Just search for install instructions for tips on here and you will find multiple threads that will help you tackle the job.
Old Dec 7, 2019 | 12:29 AM
pjdbm's Avatar
pjdbm
The biggest tip if you go this route is to leave the fasteners off the ductwork around both the foglights, theyre not needed at all and it sits well without being fastened.
Old Dec 7, 2019 | 04:49 PM
royal flush's Avatar
royal flush
outside air temp makes more power than underhood hot air--Thats rocket science-- varoom-varoom--go Vararam
