Replace Idler Tensioner Pulley ?
2001 Stock LS1 with only 80,000 miles on it, runs perfectly except for the Tensioner Pulley which is starting to squeal like a pack of pigs
It will quiet down after 5-minutes of running, and only starts again if not driven daily
A couple of quick questions:
- It looks easy enough to access and remove, any Tips?
- Can it be serviced/greased or does it need to be replaced, if so any upgrade worthy or stay stock OEM?
- Serpentine Belt looks fine, should it also be replaced at same time or wait, if so any upgrade worthy or stay stock OEM?
Thanks again and Merry Christmas to you all!
Just my 2 cents...
Just be warned that your problems could be much more than just a bad idler. The infamous belt squeak/chirp is one of the few consistent C5 sore spots. You may find that it's the belt, the idler pulleys, the tensioner pulleys, the harmonic balancer, the AC belt, the waterpump bearing or even the power steering pump. I'd recommend first looking at your balancer and looking for any wobble. If it seems to be wobbling, don't bother doing anything else until it's replaced.
Second, taking off the main belt and running the car for a few seconds will help eliminate the AC belt as a possible problem. Third, replacing the belt with a Goodyear Gatorback along with as many of the idler/tensioner pulleys as you are willing to swap would be worthwhile.
Also is Chevy Dealer OEM the best place to get the replacement Belts & Pulleys or ?
That's why I love coming here, seems to me I got me some playing around / investigation to do this holiday weekend!
Bill
I really don't get any leaks under the car, and as stated it does stop once car is warmed up, hhmm
On that Note, I may just use this opportunity to replace the Coolant Recovery Tank due to the cracked hose nipple, seems cheap design, question I see two available Tanks: AC Delco 10430189 for $90 or the Dorman 603140 for $55, any one use either or have opinion on quality etc? Want the best
Thanks!
Thanks guys!
