[Z06] 2003 Z06 valve springs
Guys I normally hang out in C7 group have 17 GS and previous 01 coupe. Question: Have heard and read about the valve spring issues with the C5 Z06. Has anyone actually had an issue or is the issue overblown. Reason I ask is I have opportunity to buy a really nice 2003 and wanted you guys opinion. Would you have them changed or is it overkill and not that widespread of a problem. Thanks
ArmchairArchitect (02-19-2020)
The upgraded springs are inexpensive and it is a 1 day DIY job to change. At the same time you can also change the valve seals, inlet manifold seals, valve cover seals - also cheap
Late 2003 models (VINs over 09000) are over 3 times as likely to experience a valve spring failure than the baseline.
The car I am looking at numbers are: 12578 so that tells me it falls into the 3 times as likely per info from stickey, am I reading this correctly? Owner is getting me the build date. Thanks
Thanks to all who responded
Bruce
