2003 shocks recommendations
Old Feb 20, 2020 | 10:11 AM
Dan Flint's Avatar
Dan Flint
2nd Gear
Default 2003 shocks recommendations
We have a 2003 corvette and like to go on long drives. I am older and have back issues and would like to up grade my shocks for a better ride. Any help would be appreciated.
dan
Old Feb 20, 2020 | 11:28 AM
C5 4 ME's Avatar
C5 4 ME
I don't know if this will help you but I will tell what I did. I have a 98 coupe and it had the F45 Real Time Damping shocks which eventually wore out. The replacements were going to be super expensive to replace. I talked to my mechanic and he suggested Koni FSD shocks which I believe are gas activated. They give a fairly smooth ride unless the road gets really rough. Remember, you are driving a sports car. You will get lots of recommendations on other brands but do some research on these shocks. From what I recall, they have a lifetime guarantee.
I hope this helps
C5 4 Me
Old Feb 20, 2020 | 04:01 PM
Dan Flint's Avatar
Dan Flint
2nd Gear
I hope this helps
C5 4 Me
thanks will check.
Old Feb 21, 2020 | 05:44 AM
awches's Avatar
awches
LOL At 76 yrs old and back problems I went with C6 Delco Easy Rides from Rock Auto when I changed shocks on my 03 Coupe last year. I'm a cruise about the back roads guy.
Old Feb 23, 2020 | 02:59 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
A few years back I replaced my stock shocks with stock GM C6 ZO6 shocks. GM Partshouse had a great price back then.My Z51 2000 Coupe loves them and so do I.
Old Feb 25, 2020 | 04:40 PM
sbadd99's Avatar
sbadd99
Same as mine, tho I did add C6 Z51 sway bars from Gene, perfect combo.
Old Feb 25, 2020 | 05:26 PM
knewblewkorvette's Avatar
knewblewkorvette
me too
Old Feb 26, 2020 | 12:52 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
I also added C6 Z06 shocks and C6 Z51 sway bars.....and an Elite Engineering thermal abs of steel tunnel plate....seems like i can now pull 4 Gs around a corner
Old Feb 26, 2020 | 01:34 PM
CQRT's Avatar
CQRT
When the magnetic ride shocks started leaking on our Anniversary, we put in stock Z06 shocks and programmed out the F45 from the ECU car's memory. The replacements for that system were about $600 each . . .the Z06 replacements were a couple hundred installed and IMO, the ride's better with no loss in handling for street use.
I'd say any OEM shock will be just fine -- NAPA, Rock Auto, etc - -I put Bilstein's on a couple of the C5s and C6s- a bit more money and potentially a little better handling but also a but more expensive.
Old Feb 27, 2020 | 07:55 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Like many of the others, we put the C6 Z06 shocks and Z51 sway bars on our car. Still young at heart, although not necessarily in years but we think our C5 has a nice ride, and many of our trips are 100+ miles, up to 1200 miles. In addition, it handles better than it did before, so a win-win for us!
To 2003 shocks recommendations
