[Z06] Max tire size squared
Old Mar 24, 2020 | 11:58 AM
R Jay MacReady's Avatar
R Jay MacReady
Thank you everyone for giving me so much helpful feedback and not making me feel like a imbecile!
Old Mar 24, 2020 | 05:03 PM
02torchred's Avatar
02torchred
No problem!
The above pics really dont represent the poke that well though. Here is a front shot (not my car) with the C5Z rears put in front, no spacers.
Old Mar 24, 2020 | 05:09 PM
USAZR1's Avatar
USAZR1
These car do not have a very sensitive Active Handling/Traction Control system so most concerns I keep reading about are overblown, IMO. Lots of people are running square tire set-ups, without issues. Even more guys are running small fronts and really big rears for roll or drag racing, without any problems.Unless your front tires are taller than the rears, I doubt you will experience any issues with your car's AH/TC.
Bossdog's post made some very good points.
Old Mar 24, 2020 | 05:11 PM
USAZR1's Avatar
USAZR1
Originally Posted by 02torchred
No problem!
Different strokes, for different folks. Personally, I would not want that much poke, on either end.
Old Mar 24, 2020 | 08:08 PM
R Jay MacReady
Yeah that does not look very good at all. l may have to rethink this whole thing haha Thank you 02 torch
Old Mar 24, 2020 | 08:11 PM
R Jay MacReady
l completely agree with you on this subject as well USA. l have read more than a few articles relating to this and they all have the same conclusion. Thank you
Old Mar 24, 2020 | 09:21 PM
smitty2919's Avatar
smitty2919
Street tires I can understand not liking the poke, race tires who cares because it's a functional thing.
C5Z rear wheels on the front with a 315 vs 295 vs 285 will have a varying degree of "poke". The silver car above looks like a 315-like poke. A narrower tier may not be so pronounced.
Old Jan 26, 2021 | 05:00 PM
Patrickd_21's Avatar
Patrickd_21
If anyone comes across this thread, if you are a fast driver driving at the limits frequently, a square setup WILL give you issues with ABS and hitting ICE mode due to the disparity between the front and rear diameters not having a difference (like intended stock). For this reason, I have had to delete my ABS system to have confidence in my brake pedal.
If you are a beginner to advanced weekend lapping guy, you shouldn't have issues. If you fall into a category above that, it may be wiser to stick with a staggered setup that conserves the stock sizing.
Just something to keep in mind
Old Jan 26, 2021 | 07:33 PM
Hitman227's Avatar
Hitman227
I would miss abs potentially, and yaw control hmm
Old Jan 26, 2021 | 07:39 PM
smitty2919's Avatar
smitty2919
Your 315 square setup was not the issue. The C5 is notorious for "ice mode" it is a combination of steering angle/brake pedal/throttle and yaw sensor. The C5 is very sensitive to brake pressure spikes vs smooth application of brakes. To delete your ABS because of that was nuts to do. Playing with brake pad compounds and driving style could have easily kept you from Ice mode IMO.
Running a 315 square setup on 10.5" speediness may be THE MOST common wheel/tire combination to run. Below that may be a 275/295 combo or 295/305 or 295/315.
