C5 Corvette Tire Question
Old Apr 20, 2020 | 01:02 AM
The coupe and vert came with runflats standard and the Z06 came with non-runflats and a plug/compressor kit. Yes, you can replace the runflats with non-runflats if you like. I did on both my 2000 and 2003 C5.
Old Apr 20, 2020 | 07:02 AM
CorvetteBrent's Avatar
CorvetteBrent
Default I carry a GTO spare on very long trips
Originally Posted by Stingroo
I dumped run flats and just carry a AAA card. Not a problem at all.
A spare tire would be pretty useless for a C5 with its staggered wheel and tire sizes.
Not in my experience. Twice, I have been stranded (once on the side of a busy Florida Interstate highway) for many hours waiting for AAA to send a tow truck. The Interstate nightmare lasted 4 hours and the other incident involve a 6-hour wait. After that, I learned my lesson. Now, when I go on long trips, I carry a 2004 - 2006 Pontiac GTO "donut" spare in the back of my C5 coupe. It is a 17" spare, so it will fit on the front axle. I had to slightly file the lug holes to make it fit. My rear rims are 18", so I could only use the spare in a dire emergency to drive a very short distance very slowly, perhaps enough to get me to the next exit without damaging (hopefully) the rear differential. I wish I could find an 18" spare so I could use it on the rear axle and on the front axle (obviously no front differential to damage).
Old Apr 20, 2020 | 08:47 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
I agree with your assessments about running non-RF tires. I'll stick with RFs, because there's no way in hell, I'm sitting on the side of the road for several hours, waiting for a flat bed to show up.
With respect to your spare tire situation, you don't need a larger diameter rim, you just need a larger OD tire, one that will match the OD of your rear tires. However, you even have to be careful in that area, too. Back when my C-5 was only a couple of years old, I had to replace one of the OE rear tires, as I had run over some debris, and cut the tire where the tread and sidewall meet, rendering the tire dangerous to use. I replaced it with another GoodYear RF.
Apparently the new tire and the OE tire wore at different rates, as when the new tire first went on, things were OK. After a few thousand miles, the rear tires wore at different rates, and the difference in ODs became more pronounced, and the posi unit in the differential wasn't happy. I pulled into work, one morning, and smelled hot gear oil. A new set of tires went on the car in short order...
Old Apr 20, 2020 | 04:38 PM
Hitman227's Avatar
Hitman227
Yes, TireRack is invaluable for researching tires. You can enter your vehicle, and it will show you all the tires they carry in the stock sizes, give it a try.
For C5Z, little more complicated, because there are no options for the front stock size. You can however enter the tire size manually, and still search there for available tires. Great!
Old Apr 20, 2020 | 04:47 PM
grampi50's Avatar
grampi50
Originally Posted by Bubba1951
Agree completely. That’s what I plan on buying when my tires age out. I currently have Nitto 555s which I am very happy with on my Base C5. I only put 2 to 3 k on each year so they age out long before they would wear out. If you put a lot of miles on your C5 you may want something that wears longer.
I'd be doing some aggressive driving on those tires before I replaced them...might as well get your money's worth from the tread before replacing them...
Old Apr 20, 2020 | 09:11 PM
Evan97's Avatar
Evan97
Originally Posted by MWWarlord
I HIGHLY recommend Michelin Pilot Super Sports. The front tire is 245/45 ZR 17 and the rear is 275/40 ZR 18. I have found that these make a HUGE difference. The one thing to keep in mind is that this is a summer tire. You can can get a good deal on these from tire rack that comes with a free warranty. I actually got a nail in mine a week after I got them, and they replaced it quickly without hassle.
I second this. These tires are great! However, it seems you can no longer get the Pilot Super Sport in the stock c5 coupe sizes anymore. I think you can only get the rear or the front, don't remember which one.
Old Apr 21, 2020 | 12:58 PM
c5arlen's Avatar
c5arlen
Gramp...
You be very careful running those tires at any speed!!... I did what you're thinking (for fun) with a favorite car of mine... Tires lost grip and slid into a freeway wall... Totaled car.😭😭 I was sick for two years!! Old tires extremely risky with a performance car.
Old Apr 21, 2020 | 02:26 PM
slothman's Avatar
slothman
can of fix a flat in a bag and good to go
Old Apr 21, 2020 | 03:21 PM
Stingroo's Avatar
Stingroo
St. Jude Donor '20-'21-'22-'23-'24
I wouldn't bother with that, personally, but yeah, you just need a 17" tire that's the same diameter as your other rear tire and that's a non-issue for the diff, too.
Tire Rack will actually shave tires for you to match tread depths and avoid that problem. We have to do it whenever we replace a blown tire on someone's Subaru at my job because of the AWD. They charge $30 per tire for this service.
Old Apr 23, 2020 | 08:17 AM
leadfoot4's Avatar
leadfoot4
I simply marvel at posts like these, and there have been MANY, over the years. In my 52 years of being a licensed driver, and the THOUSANDS of miles I've driven over that time, I've encountered 3 "flat tires". Only ONE of those, would have been able to be handled by a "can of fix-a-flat", or a portable air compressor. That was when some SOB decided it would be cute to let the air out of one of my tires, while I was at a movie theater. Fortunately, back then, my car had a full size spare tire.
The other two times I had a "tire situation" was when I encountered unavoidable debris on the road, which totally cut up the sidewall of the tire, turning the tire into instant junk. Again, I was fortunate that the cars I was driving, had some sort of spare tire.
Bottom line, based on my experience, it's RFs for me...................
Old Apr 23, 2020 | 04:42 PM
Hitman227's Avatar
Hitman227
There's a reason the 20/19 widebody stock size tires are available RFT only with Michelin, AS3, Cup 2, SS. They are one hell of good tires.
Old Apr 23, 2020 | 10:46 PM
Rustydawg's Avatar
Rustydawg
I love my Bridgestone Potenza’s!!!
