Notchy shifter.
Old Apr 28, 2020 | 09:28 PM
C5MSG2004Vert's Avatar
C5MSG2004Vert
So it looks like the shifter is a Fidanza. Took the top off and found no grease on any of the moving parts. Greased it up and now it works alot better. It's almost easy to shift. antevenom mod next.
Old Apr 29, 2020 | 11:25 PM
Daveinnola's Avatar
Daveinnola
I just work on mine with same problems today. I clean an lubed the lower shift box and clean the internals and greased the shifter itself. Then I replaced the Trans fluid with Amsoil Tourqe Drive. It is like have a new transmission. I was having trouble getting into 5th and reverse. Now I can push to 5th with one finger. And trans seems happier going from 1 to 2. Also a lot easier getting into reverse. I did the antivenom mod last year and it helped some. Glad I took the time to do it right.
