cold air intake
Old May 9, 2020 | 09:51 AM
Gordy M's Avatar
Gordy M
Unless it was a load bearing dyno, it is not going to give you the results of a street scan/log. We have had many club members thru the years who worked in the dyno room at the proving grounds and others who developed the engine coding for the C4,5,6 and 7, base and Z06/Zr1 engines engines who will disagree with you. On the C5, they would scan/log in the development stage and run a cycle including WOT to 142 mph and get the results of a chassis dyno but with the forces of weight, drag, and friction thrown in. Until the tuning software began to unravel (reverse engineer) the PCM, that was standard proceedure for many scca racers.
Old May 9, 2020 | 06:27 PM
Supercharged111's Avatar
Supercharged111
Originally Posted by Gordy M
Ram air intakes are basically a marketing term. Years ago there were articles on the ram effect of air on an internal combustion engine and as I recall it was about 4 hp at 75 mph and did not make much difference until you were at 150+ mph. For the C5 Corvette you are looking at two sources of air to the engine, those systems that are using engine bay air (which can easily exceed 150F) or outside ambient air. OF the latter, there are a few commercially available and some old standby's. Callaway and Vera-Ram are the better known with a Halltech-thu the front license plate opening-, Icebox, and Vortex. All the others are using the heated engine bay air, some are better filters than the others. The LS1 engine has over 80% of its operating (PCM) system as predetermined, unchangeable, firmware and about 19%, tuneable, of it being able to change.
You're talking about being able to exceed ambient air pressure. The thing that the Vararam and others like it likely do is reduce the pressure drop as the engine climbs in RPM to WOT. Every NA car I've logged has shown a drop in MAP as the engine approaches redline. Hell on my 1500 the drop started around 3000-3500. If all the "ram air" intake can manage is to stave off that pressure drop, it's still better than a non-ram air style.
Old May 10, 2020 | 07:56 AM
Gordy M's Avatar
Gordy M
The VeraRam at about 130 starts to loose air speed because the air intake is in a low pressure area. The true ram air intakes can be found on drag car, the sped and effects were calculated by some GM engineers using a wind tunnel and then extrapolated to higher speeds and the effects at various engineering schools.
Old May 10, 2020 | 09:38 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Originally Posted by o2bnkc
That is not a true C.A.I. In fact it's not much better than the stock system that was on there. It looks fancy though.
That is correct, this type will just take in the hot air in the engine bay. Not a good choice for performance....
Better cold air system would be the Callaway Honker. It is designed to pull in the outside air and not from the engine bay.
