‘98 owners?
Old Jun 3, 2020 | 05:23 PM
BLUDICE's Avatar
BLUDICE
Default ‘98 owners?
Does the instrument cluster light up during daytime driving?
Old Jun 3, 2020 | 05:34 PM
Blac Avy's Avatar
Blac Avy
No.
Old Jun 3, 2020 | 05:51 PM
BLUDICE's Avatar
BLUDICE
Originally Posted by Blac Avy
No.
makes it a little hard to read the gauges when driving into the sun huh?
Old Jun 4, 2020 | 08:45 PM
sjhanc's Avatar
sjhanc
I notice the few lights that are on go bright or dim depending on sunlight reflected off of my right hand on the wheel. At first I thought I had an intermittent connection, but I found that it is normal, so I don't pay attention to it anymore. There are 2 light sensors in the dash that sense ambient light levels, when the light outside gets dim (sun behind a cloud) the display is dimmed, sun comes out, they brighten.
Old Jun 4, 2020 | 09:28 PM
BLUDICE's Avatar
BLUDICE
that sounds like what was on my C4 - do you have any clue how this is controlled/ adjusted?
Old Jun 5, 2020 | 08:07 AM
BLUDICE's Avatar
BLUDICE
ok I found the light sense it’s just above the “fuel” button on the right side of the instrument cluster - same setup as the C4. You said there are 2 and I have not found the second one yet.
Old Jun 5, 2020 | 06:12 PM
sjhanc's Avatar
sjhanc
I was wrong, there is only one, the one you found. Another light sensor is located in the defrost exhaust duct for the AC, I don't know if its readings affect anything else.
Old Jun 5, 2020 | 11:42 PM
The instrument cluster did not light up during the daytime on any of the three C5s I had.
Old Jun 6, 2020 | 05:26 PM
sjhanc's Avatar
sjhanc
My 98 C5 lights the miles/kilometers indicator light whenever the ignition is on. That is the light that changes its brightness.
To ‘98 owners?
