5 spoke alum wheels question
This was the appearance as delivered from the factory. Look nice, but large areas of flaking paint just didn't do it for me. The wheels had been in storage for so long the owner forgot he had them, about 15 years. The tires had lots of tread left, but I don't trust tires older than 5 years.
I should have taken these pictures of the back side before the powder coating, sorry, I forgot. You can see that they are GM wheels.
This is after the powder coating. Total cost after the purchase, $200 for the wheels, $400 to powder coat, and $600 installed and balanced for new tires. So far, they haven't cracked, which my old wagon wheels did when new tires were installed, even a replacement wheel cracked. and one front wheel got bent somehow, but didn't cause any vibrations. The tire shop found the bent wheel when they spun them by hand on the lift.
This was taken last August, the hub caps were painted silver, one of them looked like it had been attacked with an ice pick, dozens of sharp pointed craters. I did some body work on it, using epoxy for plastics and repainted them matte black polyurethane from Home depot, then several coats of shiny clear 2 part aerosol from the online supplier I get my Torch red from. After getting them on without a scratch, I fumble fingered the air pressure gauge and nicked one wheel spoke. A dab of black paint, some fine sanding to level the spot repair and a final clear spot paint got them in usable condition, not perfect, but what used part is?
I had the mistaken impression that powder coat was a hard shell finish, it isn't. They have been on the car since last August, still look new. In the Florida sun, that's more than you can expect.
Cleaning the drums inside is much easier with these wheels, to clean the wagon wheels I had to put the car on jack stands and do the cleaning underneath using a creeper, not fun, considering how often they need cleaning.
