Recommendations on water pump
Old Jul 13, 2020 | 03:49 PM
1997 C5's Avatar
1997 C5
Default Recommendations on water pump
Well my ac compressor is leaking at the clutch so I'm going to replace one bt Delpi on amazon cost $230.00. Ac delco is $100 more. Since i have to remove the water pump and my car has almost 90k I might as well replace the water pump. I need some recomnendations on water pump brand and cost for those of you who already replaced water pump. I would like a good brand that will last but at the same time don't want to pay $250 or more just for part.
Old Jul 13, 2020 | 04:12 PM
C5R USA's Avatar
C5R USA
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Since you limit your budget to under $250, a stock replacement is your best bet. You could hypothetically find a used electric one for under that but, that's really rolling the dice, unless you know the person is doing you a huge favor with a barely used one.
https://www.corvettemods.com/C5-Corv...BoCo0UQAvD_BwE
Old Jul 13, 2020 | 04:45 PM
Will_M1911's Avatar
Will_M1911
$100 extra for the correct part seems like cheap insurance considering if the water pump fails you'll have bigger problems on your hands. I know it sucks, but there's usually a reason why some brands of parts are significantly cheaper than the "name brand."
Old Jul 13, 2020 | 08:38 PM
chevyorange's Avatar
chevyorange
Anyone in the greater Seattle area should always go to The Rebuilder! Fast, lifetime warranty. I almost wish I needed starters and alternators more often.
http://mapq.st/2yJzyVy
Old Jul 14, 2020 | 07:42 AM
feeder82's Avatar
feeder82
Ac delco 252 846 on my 02 less than 170 at summit or jegs
Old Jul 14, 2020 | 07:55 AM
CinciZ06's Avatar
CinciZ06
ACDelco 252-846 Professional Water Pump Kit
Amazon Amazon
$99 on Amazon. So I give a second for the 252-846. I’ve only
got about 400 miles on it but it pumps water, which is good.
Old Jul 14, 2020 | 07:56 AM
v6turbo87's Avatar
v6turbo87
$100 on Amazon, free shipping:
Amazon Amazon
Old Jul 14, 2020 | 08:50 AM
StingrayRebel's Avatar
StingrayRebel
ac delco often offers a cheaper replacement part and the actual oem part, if it were my car I would go for the oem pump
To Recommendations on water pump
