Skid Stiffners
Old Jul 21, 2020 | 09:05 PM
aclassicnut's Avatar
aclassicnut
Veteran: Marine Corps
Veteran
Default Skid Stiffners
New owner of a 50AE convertible............................. ...I have seen these in a few online catolgues. "Skid Stiffners". So I went out in the garage to look at the bottom side of front bumper. Sure enough, scrapes and gouges.
My question is ....Has anyone here intalled these and do they work. If so how are they attacted? Pics would be great!
Still aclassicnut
Old Jul 21, 2020 | 09:43 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
I thought about adding a set of those a long time ago. I also considered the ones with roller skate wheels, but simply ended up adding a set of Fangs. Easy install and if scraped, a simple light sand and Armor All will make them look like new. Below is a picture of the original white fangs so you can see them. I later swapped them for the black Fangs which you can't really see but still protect the radiator frame rails.
Old Jul 21, 2020 | 10:18 PM
aclassicnut
Veteran
Thanks for the reply MSG
A c l a s s i c n u t
Old Jul 22, 2020 | 05:52 AM
I also ran a set of the Fangs on my C5 - they do work to protect the lower radiator support from damage.
Old Jul 22, 2020 | 08:25 AM
6speedsteve's Avatar
6speedsteve
I have the Fangs, and if I scrape I just touch them up with a sharpie marker.
Old Jul 23, 2020 | 03:52 PM
lebeeby's Avatar
lebeeby
I took some 3/16 X 1" mild steel, bent it to the right shape and laid over the lower radiator support and bolted it on. Painted it black, can't see it, and if it gets messed up too bad, I will just replace with the same.
Old Jul 24, 2020 | 07:45 AM
BLUDICE's Avatar
BLUDICE
Ok I give up - how do I find the Fangs?
Old Jul 24, 2020 | 08:41 AM
zzcop8's Avatar
zzcop8
SacCityCorvette.com has them listed. I just ordered a set
Order: shipped same day as ordered
Old Jul 24, 2020 | 11:15 AM
Clancy209's Avatar
Clancy209
My driveway Is steep I installed Fangs a few years ago
Thank you for reminding me to check them
To Skid Stiffners
