Driving seat back broken
Old Jul 28, 2020 | 01:56 PM
punk86's Avatar
punk86
Default Driving seat back broken
My stock driver seat just falls back rather than resting against my back unless i have the seat all the way back which is useless to me. What do I need to fix this, even if only temporary.
Old Jul 28, 2020 | 04:14 PM
MWWarlord's Avatar
MWWarlord
St. Jude Donor '21-'22
I've not heard of this before. Ultimately, I suspect you'll need to replace the seat. However, as a short term cheap fix you could try shoving a couple of pillows between the back of the seat and the rear bulkhead. It's a crappy solution, but I don't know anything better.
Old Jul 28, 2020 | 04:23 PM
SilverC54me's Avatar
SilverC54me
Are you saying that when you put pressure on the seat back it pops out of the position it is in and goes all the way back?
If so the recline mechanism cylinders are worn out. They can be replaced. The seat has to come out to repair, seat bottom has to be taken apart.
Gary
Old Jul 28, 2020 | 05:52 PM
4XLR8N's Avatar
4XLR8N
Pro Mechanic
Gary
Old Jul 28, 2020 | 06:34 PM
3sACROWD's Avatar
3sACROWD
They may not be worn out but out of sync. With the seat all the way back, lift the tilt lever and rotate the seat back all the way forward towards the steering wheel. Release the lever and rotate seat back to normal position. Do the same with the lever behind the headrest. It may take a couple of attempts.
Worth a try or two and costs nothing.
Old Jul 28, 2020 | 07:43 PM
punk86's Avatar
punk86
Gary
Yeah, the driver's seat is constantly fully reclined.
To Driving seat back broken
